Mux213 Levin GTS
08-20-2006, 05:59 PM
Post: #291
Mux213 Levin GTS
will do
![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
09-18-2006, 01:17 PM
Post: #292
Mux213 Levin GTS
Thanks to the 2 year anniversary drive I got a new picture of my car
![]() ![]() As you can see I've been very busy on my front fenders. They are currently in a new coat of paint. I also filled the holes where the blinkers where and the antenna was with fiberglass and filler. I need to sand a few bit and fill 2 small bits that turned out not to be correctly filled with filler. Then one more coat of paint and finally finish it off with a clear coat. Hopefully it will then match the rest of the car again ![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
09-18-2006, 01:27 PM
Post: #293
Mux213 Levin GTS
Note,
The painting is just a cheap temp solution for now so even if the paint doesn't match up 100% I'm not stressed. I'll be fixing up my rear bootlid next and welding up some other bits. also noticed some rot above my windscreen setting in and around my filler cap so those need to be addressed. When all that is done, and I'm satisfied all the rust of my car is fixed, I'll properly sand her down and give her a respray, but that wont be until a year or two from now.. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
09-18-2006, 06:57 PM
Post: #294
Mux213 Levin GTS
Muxi, if you used my guide on closing holes in wings, you wouldnt have to use filler more than one time :wink:
A good trick is painting with flat primer when you think the surface is straight. When its dry its easy to see where it needs more filler. You can also use sprayfiller on a rattlecan. It took me about an hour to close the antennahole (not including time for filler and primer to dry) and the result is perfect. You remembered to use "body-kit" on the back of the fender right? If you dont, the hole will get moist and the fiberglass will sink, and you dont want that to happen ![]() Youtube Myspace and I´ll Google your Yahoo |
09-18-2006, 08:50 PM
Post: #295
Mux213 Levin GTS
Knudsen, I know, I'm using that trick on the RX7, with the hachi it just became to late and I rushed it a bit. I thought I had gotten it right (I had already sanded that part twice) and didn't figure I had missed some after I already painted it the right color.
I did the right side fender perfect though, no signs on that fender there was ever a hole there ![]() Body kit? I put a layer of tectile on the back ![]() ![]() Awell by the time its time for a complete respray of the car there is a good change I'll remove this stuff and weld in some proper metal bits anyways ![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
09-25-2006, 08:29 PM
Post: #296
Mux213 Levin GTS
Got myself a new little steering wheel
![]() ![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
09-25-2006, 09:20 PM
Post: #297
Mux213 Levin GTS
Looks great!
09-25-2006, 10:08 PM
Post: #298
Mux213 Levin GTS
Yup, looks cool.
Nice job on the price to. ![]() ![]() Toyota MR2 2.0 16V Gen3 Turbo Toyota MR2 1.6 16V Toyota Corolla GTZ Twincam 1.6 16V (AE86) (Sold. ![]() Toyota Corolla GT Twincam 1.6 16V (My new project ![]() |
09-25-2006, 10:24 PM
Post: #299
Mux213 Levin GTS
Nice
danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
09-26-2006, 10:26 AM
Post: #300
Mux213 Levin GTS
Did the steering become a lot more heavy? I once drove an old corsa with a tiny wheel and that one just tried to wrestle itself out of you grip every time things got interesting.
Can you also still see the instruments in the dash? A wheel to steer the front of the car A pedal to steer the rear |
Deaty's GTS Project | Deaty | 9 | 5,483 |
04-27-2021 06:10 AM Last Post: Deaty |
1985 Corolla GTS Project | mattscar | 5 | 10,912 |
01-30-2011 07:30 AM Last Post: mattscar |
My SR5 to GTS Restoration Conversion. | Lofty | 15 | 20,398 |
09-25-2009 06:52 AM Last Post: Lofty |
My 1985 Toyota Corolla GTS Hatchback Project (2002-Present) | ryceboy_124 | 4 | 22,814 |
08-05-2009 04:25 PM Last Post: Eric |
AE86 Trueno Coupe (SR5-GTS)//Sweden | Allexz | 71 | 78,177 |
03-16-2009 10:02 PM Last Post: banpei |
User(s) browsing this thread: 20 Guest(s)
