Mux213 Levin GTS
01-15-2007, 07:04 PM
Post: #431
Mux213 Levin GTS
Its possible doc, though I have the rattling under braking aswell if I remember correctly...
01-15-2007, 08:20 PM
Post: #432
Mux213 Levin GTS
hmm, i don't.
As soon as the brakes are slightly applied, the rattling stops. "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
01-22-2007, 12:02 AM
Post: #433
Mux213 Levin GTS
Tonight spent a little time on our cars, just me and Banpei. We needed to check out Banpei's car for oncoming MOT. Found a few things we didn't like so hopefully it won't be bad enough yet.. Also put my old APEX springs in the back, we still need to do the front but we'll do that when we have more time to spend.
In the mean while I took the opertunity to figure out why I had a rattle coming from one of the new struts. Turned out to be a small problem, we had forgotten to tighten one of the top nuts that hold the strut in place (the center one way at the top). We tightened it and away was this problem. Also decided to put some decals on the back lid only to find out black may not be the right color to put on blue A well I need a new bootlid anyways so its only temporary. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
01-22-2007, 12:40 AM
Post: #434
Mux213 Levin GTS
still looks n1 trhe label :-)
I got a little scared on what you said. Because I tightent the lower bolts ;-D Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
01-22-2007, 01:16 AM
Post: #435
Mux213 Levin GTS
Not the lower ones Robo, the upper one
We tightened one together very well, the other was tightened by Jordy and Ibrahim. I think they didn't know you had to hold on to the dishy thing to stop the shock shaft from turning with the nut. I don't think it is a real problem, under compression it all stays pretty nicely in place, just over bumps it comes loose. I do need to soften the HTS' a bit, the ride is pretty good but I had one place where I drove of tarmac that was slightly rolled up by jammed traffic and then wasn't nice at all... I think the guy in the souped up MX5 next to me had a good laugh Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
01-22-2007, 01:23 AM
Post: #436
Mux213 Levin GTS
Black isnt that bad, but perhaps grey/silver would be better.
a quick question, when you lowwer the car via untightening the spring, lets say all te way down, does the spring come loose when you jack the car? |
01-22-2007, 01:42 AM
Post: #437
Mux213 Levin GTS
Apolan,
The current ride height is the lowest possible without the spring coming loose when the car is jacked up. Turn it lower and the spring will come loose most likely, you have some play because the arm doesn't lower fully you can press it down a little more to extent the shock to maximum length. (what I did was extent the shock to maximum length, then rotate the base up until the spring was locked in place. That pretty much resulted in this ride height, call it lucky ) Off course there is still a 2cm spacer underneath the tokico so if you want everything even lower you could use an even smaller spacer and shorten the strut even more. That way the spring won't come loose. Off course also getting custom springs made with some measure of progressiveness in them will solve your problem as well as these springs are longer when there is no load on them then linear springs. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
01-22-2007, 04:51 PM
Post: #438
Mux213 Levin GTS
Tnx! Good job!
01-22-2007, 06:40 PM
Post: #439
Mux213 Levin GTS
On camera the stickers look better readable than when I saw them, perhaps it's due to the flashlight.
How are they during daylight? 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
01-22-2007, 06:47 PM
Post: #440
Mux213 Levin GTS
Dunne know, haven't seen any daylight yet
Deaty's GTS Project | Deaty | 9 | 5,201 |
04-27-2021 06:10 AM Last Post: Deaty |
1985 Corolla GTS Project | mattscar | 5 | 10,747 |
01-30-2011 07:30 AM Last Post: mattscar |
My SR5 to GTS Restoration Conversion. | Lofty | 15 | 19,805 |
09-25-2009 06:52 AM Last Post: Lofty |
My 1985 Toyota Corolla GTS Hatchback Project (2002-Present) | ryceboy_124 | 4 | 22,652 |
08-05-2009 04:25 PM Last Post: Eric |
AE86 Trueno Coupe (SR5-GTS)//Sweden | Allexz | 71 | 75,377 |
03-16-2009 10:02 PM Last Post: banpei |
