My 1986 ae86
11-27-2011, 11:37 PM
Post: #41
My 1986 ae86
To answer a few of your previous questions,
don´t go to crazy about your intake system!!! Silicon reducer, hardpipe, headshield, airfilter. Job done, I run a hose from behind the bumper to behind the headlight to draw in some fresh air.
I do belive carpets are the same on 2dr´s and 3dr´s (exept for the boot carpet) no matter if its SR5 or AE86, the gearstick hole is differnt on automatics.
I run NGK iridium spark plugs, they´re a little more expensive than OEM, but well worth it, much nicer spark. Watch for the right heat grade, tho!
About the fan conversion, I don´t really like the viscous fan, they get old, have poor efficiency and will steal a little power from your engine (rotating mass).
A proper electric, even better termostatic, setup will be better.
It also leaves you with more space in front of your engine, very handy if you work on alternator/cambelt etc.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
11-28-2011, 05:57 PM
Post: #42
My 1986 ae86
Thanks for the answers Smile
That would be great,planning on using the carpet for the back for inspection and normal driving.
If i check this guide
For NA cars usually use a grade 6 for most road applications, a grade 7 can be used in hi compression race type cars, grade 8 in extreme rev/compression cars.
grade 6 looks like the right choice then?
12-01-2011, 06:40 PM
Post: #43
My 1986 ae86
pic
12-01-2011, 06:47 PM
Post: #44
My 1986 ae86
pic?Smile
12-03-2011, 05:02 PM
Post: #45
My 1986 ae86
Installed the trd cables.
Also replaced the distributor cap and rotor arm,they were showing there age.
pics
http://i41.tinypic.com/678t21.jpg
http://i42.tinypic.com/34gmvkg.jpg
12-04-2011, 01:08 AM
Post: #46
My 1986 ae86
Hm still trying to find the problem i have.
The bushings look fine
Sounds from the back i tried to make a video of it
http://youtu.be/SZN5mfiwRyc
anyone have any idea?
12-25-2011, 01:14 PM
Post: #47
My 1986 ae86
updates:
replaced the bfront bumper brackets,they were broken and not even attached
http://i44.tinypic.com/91exk3.jpg
beginning rust removed
http://i41.tinypic.com/noy5og.jpg
http://i43.tinypic.com/16c5cn7.jpg
gearbox cleaning
http://i40.tinypic.com/33aqeeh.jpg
ordered AP Racing PRF660 brakefluid
ordered brake booster heat shield
ordered terratrip intercom system
I have also decided on the rollcage i will be using,the design is like this(forgive my drawing skills)
http://i40.tinypic.com/amdrbo.png
because of regulations the last part will be before the trunk part of the coupe,so not cutting wil be done there like this
http://i43.tinypic.com/25oxdug.jpg
Would it be a good idea to remove the tar and replace it with por15?
I can't see any starting rust this way and it weights probably alot
I will also remove the tar from inside and then repaint it
12-26-2011, 12:06 AM
Post: #48
My 1986 ae86
ditn Wrote:updates:
I hope you didn't pay to much for those side brackets. I took these off and threw them away.
ハチロク
[Image: AEU86 AE86 - My 1986 ae86]
12-26-2011, 07:12 PM
Post: #49
My 1986 ae86
7,5€ for both
Anyone have any idea which cable this is
http://i40.tinypic.com/35k936d.jpg
http://i40.tinypic.com/f9e4at.jpg
Comes from leftside but was not connected and disappears in the roof
music cable?
And a small update
http://i39.tinypic.com/2vb0ux1.jpg
removing deadening soud material
12-26-2011, 07:29 PM
Post: #50
My 1986 ae86
Cable seems to be from the roof antenna.
ハチロク
  1986 Corolla SR5 S2k Build.... MIami style geoscranny84 16 22,336 04-26-2012 08:00 PM
Last Post: [Walaki]D`Lair
  Saw the light -> My 1986 AE86 project IBMFD3S 37 30,952 08-08-2011 02:13 AM
Last Post: IBMFD3S
