My 20v swap
03-06-2008, 09:54 PM
My 20v swap
Just finished my 20v swap in my ae86. Just need an o2 sensor and new rad. The vvt sproket is very noisey as you can hear in the video clip iswell.
[Image: AEU86 AE86 - My 20v swap]
http://www.youtube.com/watch?v=5bkEVDXfHr8
03-06-2008, 10:31 PM
My 20v swap
Looks nice Smile , what did you do regarding the cooling? Did you use a water line relocation kit? If so, which one?
03-07-2008, 10:04 AM
My 20v swap
rikard Wrote:Looks nice Smile , what did you do regarding the cooling? Did you use a water line relocation kit? If so, which one?
Ya i used the rs chita water line kit.
03-07-2008, 11:16 AM
My 20v swap
Nice work! I'm prepping my blacktop to go in at the moment. I hope to drop it in this year Smile
03-07-2008, 01:18 PM
My 20v swap
The RS Chita waterline kit's a tidy one - much nicer than the other offerings. Did your's have a problem clearing the bulkhead? We had to lower the front mounts and raise the rears a bit, to make sure it wouldn't hit.
The SP Tech rotor arm mount and rotor cap need to be well centred, as they're not automatically centred. We found we needed to make a simple tool to do this...
Needs to be a black top O2 sensor btw - not same as an AE86 one, if you're using the std. ECU.
Hope this helps, anyways.
VISIT OUR NEW WEBSITES!!!!
A Tuner's Paradise
Automotive Art On Film
03-07-2008, 03:07 PM
My 20v swap
Ya i got a centering tool with the kit. Im using a wideband sensor and controller, but the 20v's ecu isn't working from the narrow band output from the controller. So i had to buy a unversial denso 4 wire o2 from ebay.
I had no issues from it hitting the bulkhead, only trying to get the engine back in which was a pain.
03-07-2008, 03:17 PM
My 20v swap
Any pics of the water line kit mounted on the engine?
For me a kit like that is too expensive but I would love to see how much clearence there is to the firewall Smile
03-07-2008, 06:37 PM
My 20v swap
Its too bloody expensiveSmile
No pics, but i can fit my hand between the bulkhead and water outlet at the back of the block if thats any help.
03-07-2008, 08:40 PM
My 20v swap
I just wanted so see if this would work:
Smile
03-07-2008, 10:48 PM
My 20v swap
Ya it should no bothers.
