My 86
12-09-2007, 12:01 AM
My 86
Hey, new here, been looking through other peoples threads, so I though I should probably put my car up.
It's a 1984 Trueno GTV
Engine:
Super Charged 4AGE 20V Silvertop
SC12
4agze MAP / DLI- multicoil ECU with a Gizzmo piggy back
V-Mount Intercooler
Twin core custom radiator with electric fan
Custom alloy Inlet manifold and intercooler piping
Oil Catch can
Ignition coil's mount inside car
De-loomed, Engine loom minimised, engine bay wiring hiden, anything forward of drivers seat not required removed.
4-1 Exhaust manifold lagged
2 1/4 inch exhaust
Driveline:
4agze 6 kg flywheel
225mm solid centre 4 puk ceramic
H/D pressure plate
Nite Parts CNC 4AG - W5# Bell housing
W58 Supra Gearbox - Steel sandwich plate version
Drive-Inn custom 2 peice driveshaft
G series diff (Hilux)
1.5 rebuilt 4.3 ratio LSD
Suspension:
Front - Trd short stroke front shock
8 kg/mm height adjustable - About to change to TRD lowering springs - The coilovers are just too hard for the roads round my place.
Rose jointed front arms (standard spare)
K-Style Tie rod end spacers
Rear - Rose jointed molly pan hard rod
6kg/mm rear Trd spring - All ready changed to the TRD lowering springs
H/D short stroke shocks
Brakes:
Front - Mazda FC RX-7 4 pot caliper and rotors
Rear - Mazda FD RX7 rear calipers large vented rotors
FD hand brake system
Wheels:
15 x 7jj ROH +7 offset
195/50 fronts
195/45 rears
Exterior:
Subaru 2pac cream
Drop vent in bonnet
Passenger and hatch door locks removed
Flared front gaurds
Fibre glass rear flares glassed onto body
Interior:
Tomei Steering wheel
Buddy club gear knob
Cusco fixed back drivers seat
RJS 3 inch 5 point cam lock harness
Splitfire boost gauge
Performance:
Last 1/4 mile
13.7 @ 160 kmph
145kw at the wheels
Some pictures below, not the best but I want to get the new wheels and other bits and pieces before I take some more.
I hope to get the chassis all cleaned up and restored, I like the car, and want to keep it for a long time so I think it's worth it.
I'm not sure what I'm going to do for an engine soon, it's either a hard out turbo, or a mild N/A setup, but I'm undecided yet.
Any advice or questions feel free to ask Big Grin
[Image: AEU86 AE86 - My 86]
Can't really see it, but the piggy back gizzmo fuel controler is mounted in the clock space
Custom intake manifold with 3S-GTE throtal body and 7M-GE injectors
You can sort of see the custom mounts for the supercharger here, and the inlet/outlet of it
Custom (butchered) alternater bracket
You can see the normal water outlet to the radiator blocked up on the head, also the cam angle sensor, and the coil leads coming from the cabin
You can see the pipe that normaly goes from the head to the water pump has been modified. It's now the out let, and the inlet from the radiator goes to the external thermostat then to the water pump
12-09-2007, 12:25 AM
My 86
Nice! Very nice indeed!
12-09-2007, 01:38 AM
My 86
Banging head excelente one video please Thumbs up!
12-09-2007, 01:44 AM
My 86
The only one I have is of it crashing Sad
http://www.youtube.com/watch?v=Jbu4uj9x0SQ
Thats back before most of the work though, it had a standard 4agze in it then when the previous owner had it.
I would like to get some vids, I'll see what I can do Smile
12-09-2007, 01:52 AM
My 86
Sorry Angry
12-09-2007, 01:57 AM
My 86
It's all good, it wasn't as bad as it looks, didn't even bend the radiator support, just the bonnet, gaurd and bumper. Thumbs up!
12-09-2007, 03:23 AM
My 86
n1 car. though th power output sucks if you ask me ? 145 kw with that type of engine. If you port the silvertop head it would help alot. The standard silvertop head is not that good.
And use a programmable ecu and you'll be making alot more power.
I have to say I am not yet sure about your rear arches. Was thinking of doing the same thing with mine but I dislike the mounting points.
The car it selve looks cool did you spent much on the rbuild of the chassis?
12-09-2007, 04:07 AM
My 86
I haven't restored it yet, it's on the to do list. The arches have too much curve I think, I will go back to a more straighter standard type but wider I think.
The power isn't too bad when you consider it's only 10psi off boost, and the engine is dead stock internaly. It could do with a decent exhaust though. It's makes more than enough to get it moving for now, so I'm not too worried about it.
The new engine, once I get around to building it will be running on a mega squirt so it will drive alot nicer.
12-09-2007, 12:06 PM
My 86
Looking good! Nice list of parts!! And I like those rims very much Thumbs up!
