My 86
12-09-2007, 12:01 AM
My 86
Hey, new here, been looking through other peoples threads, so I though I should probably put my car up.
It's a 1984 Trueno GTV Engine: Super Charged 4AGE 20V Silvertop SC12 4agze MAP / DLI- multicoil ECU with a Gizzmo piggy back V-Mount Intercooler Twin core custom radiator with electric fan Custom alloy Inlet manifold and intercooler piping Oil Catch can Ignition coil's mount inside car De-loomed, Engine loom minimised, engine bay wiring hiden, anything forward of drivers seat not required removed. 4-1 Exhaust manifold lagged 2 1/4 inch exhaust Driveline: 4agze 6 kg flywheel 225mm solid centre 4 puk ceramic H/D pressure plate Nite Parts CNC 4AG - W5# Bell housing W58 Supra Gearbox - Steel sandwich plate version Drive-Inn custom 2 peice driveshaft G series diff (Hilux) 1.5 rebuilt 4.3 ratio LSD Suspension: Front - Trd short stroke front shock 8 kg/mm height adjustable - About to change to TRD lowering springs - The coilovers are just too hard for the roads round my place. Rose jointed front arms (standard spare) K-Style Tie rod end spacers Rear - Rose jointed molly pan hard rod 6kg/mm rear Trd spring - All ready changed to the TRD lowering springs H/D short stroke shocks Brakes: Front - Mazda FC RX-7 4 pot caliper and rotors Rear - Mazda FD RX7 rear calipers large vented rotors FD hand brake system Wheels: 15 x 7jj ROH +7 offset 195/50 fronts 195/45 rears Exterior: Subaru 2pac cream Drop vent in bonnet Passenger and hatch door locks removed Flared front gaurds Fibre glass rear flares glassed onto body Interior: Tomei Steering wheel Buddy club gear knob Cusco fixed back drivers seat RJS 3 inch 5 point cam lock harness Splitfire boost gauge Performance: Last 1/4 mile 13.7 @ 160 kmph 145kw at the wheels Some pictures below, not the best but I want to get the new wheels and other bits and pieces before I take some more. I hope to get the chassis all cleaned up and restored, I like the car, and want to keep it for a long time so I think it's worth it. I'm not sure what I'm going to do for an engine soon, it's either a hard out turbo, or a mild N/A setup, but I'm undecided yet. Any advice or questions feel free to ask ![]() ![]() ![]() ![]() ![]() ![]() ![]() Can't really see it, but the piggy back gizzmo fuel controler is mounted in the clock space ![]() Custom intake manifold with 3S-GTE throtal body and 7M-GE injectors ![]() You can sort of see the custom mounts for the supercharger here, and the inlet/outlet of it ![]() Custom (butchered) alternater bracket ![]() You can see the normal water outlet to the radiator blocked up on the head, also the cam angle sensor, and the coil leads coming from the cabin ![]() You can see the pipe that normaly goes from the head to the water pump has been modified. It's now the out let, and the inlet from the radiator goes to the external thermostat then to the water pump ![]() ![]() ![]() |
12-09-2007, 12:25 AM
My 86
Nice! Very nice indeed!
Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
12-09-2007, 01:38 AM
My 86
12-09-2007, 01:44 AM
My 86
The only one I have is of it crashing
![]() http://www.youtube.com/watch?v=Jbu4uj9x0SQ Thats back before most of the work though, it had a standard 4agze in it then when the previous owner had it. I would like to get some vids, I'll see what I can do ![]() |
12-09-2007, 01:52 AM
My 86
Sorry
12-09-2007, 01:57 AM
My 86
It's all good, it wasn't as bad as it looks, didn't even bend the radiator support, just the bonnet, gaurd and bumper.
12-09-2007, 03:23 AM
My 86
n1 car. though th power output sucks if you ask me ? 145 kw with that type of engine. If you port the silvertop head it would help alot. The standard silvertop head is not that good.
And use a programmable ecu and you'll be making alot more power. I have to say I am not yet sure about your rear arches. Was thinking of doing the same thing with mine but I dislike the mounting points. The car it selve looks cool did you spent much on the rbuild of the chassis? Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
12-09-2007, 04:07 AM
My 86
I haven't restored it yet, it's on the to do list. The arches have too much curve I think, I will go back to a more straighter standard type but wider I think.
The power isn't too bad when you consider it's only 10psi off boost, and the engine is dead stock internaly. It could do with a decent exhaust though. It's makes more than enough to get it moving for now, so I'm not too worried about it. The new engine, once I get around to building it will be running on a mega squirt so it will drive alot nicer. |
12-09-2007, 12:06 PM
My 86
Looking good! Nice list of parts!! And I like those rims very much
