My 86 GTS won't stay on.
04-08-2014, 02:36 AM
I bought a 86 corolla the other day and the car didn't start but it was cuz the fuel pump didn't get power so I put a toggle switch on it to give direct power now it works an turns on sounds great the motor is running strong but when I let it idle it dies slowly, sometimes it stays on but most of the time it dies. I can't figure out what the problem.
04-08-2014, 11:51 AM
Check the circuit open relay & efi main relay. Efi relay in the engine bay, & as far as I remember the circuit open relay is in the passenger compartment either next to the fuses or near the ecu...
04-08-2014, 12:13 PM
Check the ecu for error codes.
AFM or MAP engine ? An analogue brain in a digital World |
Won´t start | AlexKTM | 6 | 17,890 |
12-04-2017 10:05 PM Last Post: banpei |
where to start on sr5-GTS swap | dinkers542 | 0 | 3,400 |
12-20-2014 02:13 AM Last Post: dinkers542 |
anyone produce new harness for bluetop?gts driveshaft | dinkers542 | 8 | 8,705 |
11-25-2014 09:18 PM Last Post: dinkers542 |
3rd door support gas springs (stay) - worn out | max_ae86 | 5 | 6,452 |
09-01-2013 03:20 PM Last Post: Jezza_hr |
my bluetop 4a-ge won't start HELP | Lykowsky | 4 | 5,951 |
07-04-2013 10:00 PM Last Post: Lykowsky |
