My Ride
08-09-2012, 10:34 PM
Post: #241
My Ride
;D ;D I'm so JDM I put everything sideways. AE86 owner |
08-14-2012, 03:00 AM
Post: #242
My Ride
08-14-2012, 11:26 AM
Post: #243
My Ride
awesome work man keep it up!
ALWAYS SIDEWAYS!!!!! |
02-20-2013, 07:44 PM
Post: #244
My Ride
hi people from 86 world
sorry for no post for a while so lets update this had several problems during wiring the 4agze loom into the ae86. fuse box wiring of the GZE was cut and didnt have it . the wiring loom had ABS and shitload os sensor did were no need for them. open the loom and done wire by wire. also got change the injectors wiring due to diferent ohms. the 4agze igniter was a pain to get so i found some info online that the 7mgte was easy to modify and work good so i got one and the car is working fine one that there is a vacum trick also to put the BOV working with more presure so now the car is running 0.8 on full boost. the OEM vacum piping dont let you go over 0.7 this is a clip of the 10th start lolol http://www.youtube.com/watch?feature=pla...bTykM8xeAw I'm so JDM I put everything sideways. AE86 owner |
02-20-2013, 08:07 PM
Post: #245
My Ride
since the GZE was a DLI version have to change 2 resistance on the loom to have Reving on the tach the loom was so good that i also have the 180kmh fuelcut ahah
so this is the 0 to 180 with 2 fat ass guys inside and easy on pedal so the clutch wont slip http://www.youtube.com/watch?v=F4KquRYSUsU 177 GPS 205km on the dash fuel cut at 6200rpm the car does near 8000rpm my exedy stage 2 did not hold the spec was This Exedy Stage 2 Cerametallic Thick Clutch Kit Toyota Corolla GT-S 1.6L 1985-1987 has the following feature: Torque Capacity (ft/lbs) - 162 Clamp Load (lbs) - 1210 Disc O.D. (mm) - 200 Spline Teeth/Major Dia. (mm) - 21T / 24.1 Clutch Disc Material - Cerametallic Number of Disc - Single so 215 nm didnt hold here is a video 2012 Portugal meet http://www.youtube.com/watch?feature=pla...c-5cJVSs#! here a test in the track on 4 gear i can get 180kmh so i dont need 5 gear thats why i dont throttle on the end of the lap http://www.youtube.com/watch?feature=pla...zFuATOFzG4 I'm so JDM I put everything sideways. AE86 owner |
02-20-2013, 08:16 PM
Post: #246
My Ride
fun times
http://www.youtube.com/watch?feature=pla...TzQxYIfNV8 on the first week of 2013 the clutch died so the 86 was like this from merica with love so yesterday so its in surgery for the new clutch mazda brakes and steering tune up I'm so JDM I put everything sideways. AE86 owner |
02-21-2013, 11:53 PM
Post: #247
My Ride
good read
now i want my 3AGZE even more |
02-22-2013, 12:19 AM
Post: #248
My Ride
02-22-2013, 06:38 PM
Post: #249
My Ride
02-26-2013, 04:59 AM
Post: #250
My Ride
Scrapper's ride | Scrapper | 30 | 33,625 |
09-28-2012 05:18 AM Last Post: kennedy8383 |
