My drift mix stage2
12-08-2007, 09:39 AM
My drift mix stage2
stage 2 is up!
<br>
<br>
<br>
what do you think? Confused
AJC
'85 GTS coupe - ghetto and half broken | '86 SR5 hatch - soon to be swapped & caged
My Website
My Myspace
12-09-2007, 02:12 PM
My drift mix stage2
I think you need stiffer springs and repair your right side-light (or break your left). Tongue
[Image: AEU86 AE86 - My drift mix stage2]
12-09-2007, 05:17 PM
My drift mix stage2
Think in using some cones. That way you can learn a lot faster as you have some references. Doing drifts in a open space (i mean with no references/cones/defined path whatsoever, never near trafic) is like having sex with the cloth on.
Cump´s
Filipe Oliveira
12-09-2007, 09:18 PM
My drift mix stage2
I do need stiffer springs. Good call on the light, I would never have noticed that! Huh I thought you were crazy at first, but then I looked carefully and noticed it.
Yep, cones are next.
AJC
My Website
My Myspace
12-10-2007, 12:00 AM
My drift mix stage2
well you'll get the hang of it. The car will be easier to control with stiffer springs. Let me share a secret which I found out.
The back of the cars supension is one of the biggest spots that does the body roll. I found that out while doing some testing with springs.
12-10-2007, 12:26 AM
My drift mix stage2
ye when i watched the footage of me skidding saturday i noticed to back seemed to roll more than the front of the car, i only have lowering springs right now.
No Smorking AE86
12-11-2007, 08:51 PM
My drift mix stage2
I'm guessing that is probably a result of having a solid rear axle setup instead of IRS...
And yeah, on my GTS coupe I can really see how stiffer suspention helps. That, and an LSD plus a 4age of course :wink:
AJC
My Website
My Myspace
  mini.....hip hop mix by me ae86driftmaster 2 4,301 03-15-2010 03:34 AM
Last Post: yaun
  Sex &amp; Violence while Stool pigeons are Listening Mix... ae86driftmaster 3 5,151 01-07-2010 04:20 PM
  [ DRIFT ] GRUIII DRIFT TEAM strikes back darkandier 4 6,796 02-28-2007 02:43 AM
Last Post: darkandier
  [DRIFT DEMO] LU DRIFT SERIES - Clashproduction AE86 darkandier 6 7,282 02-03-2007 02:18 PM
