My little (not really...) project - Soon to be all done?!?
11-24-2011, 08:58 PM
Post: #481
The second box just got in today straight from the UK
Yeah the high mid end is quite good but it needs a better exhaust to free the last 10 hp at 7.5k rpm And since my old exhaust broke at the last trackday I might do something about it However I do believe that the new gearbox will do more good than a bit of extra power Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
11-25-2011, 12:36 PM
Post: #482
A gearbox with good gear ratios can disguise a bad engine (which is not the case) and a gearbox with bad gear ratios can ruin a good engine.
Keeping the AE86 alive! |
12-17-2011, 12:01 PM
Post: #483
awsom som day you will get it back on the street right lol
12-17-2011, 11:09 PM
Post: #484
It is, Mikkel - well not now durring the winter - but it has been running all season. Including two trips to the Nürburgring
01-05-2012, 12:30 PM
Post: #485
Yep it is.
Okey sweet i hope the 6speed Will work then i want one also |
06-18-2012, 06:45 PM
Post: #486
T50
Lexus IS200 AZ6 T50 clutch housing: AZ6 clutch housing: Final measuring... ...Before milling: To be continued... Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
06-18-2012, 09:08 PM
Post: #487
why you just make adapter plate between is stock is bellhouse and a engine. not hard to do and you dount need to ruin t50-a engine bellhouse
i do whit stock is bellhouse and adapter |
06-19-2012, 10:34 AM
Post: #488
Thats not possible or at least very hard to do. There aren't enough room for the bolt heads...
My friend Martin did make an adaptor for his 3SGE AZ6 which has a bigger housing... And that wasn't easy either :wink: It is working, though, and the 3, 4, 5, 6 are layed out real nice for the Ring Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
06-19-2012, 06:56 PM
Post: #489
very easy to make adapter. just use the bigger genuine is200 bellhouse and then from alumium make adapter to engine. bolt the aluminium to block and then holes to fit is200 bellhouse to it.
IF i could do it in my garage every one else can to. Good drill and some saw to cut shape. Measure measure and cut onse. |
06-19-2012, 06:59 PM
Post: #490
Ivan's coupe: bodywork is done | Ivan141 | 676 | 766,227 |
08-07-2024 08:46 AM Last Post: banpei |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,438 |
OST-066: I get all wavy (4AC content) | oldeskewltoy | 10 | 13,109 |
04-03-2020 04:29 PM Last Post: Power_uP |
d3nso's little AE86 N2 build | d3nso | 27 | 33,965 |
11-13-2017 11:42 AM Last Post: mad.matt |
Doc's KE20: - really coming together now | The Doctor | 548 | 504,993 |
08-03-2011 11:57 AM Last Post: The Doctor |
