Need a little HELP with the diff rebuild
03-27-2007, 08:57 PM
hi there i am about to rebuild my rear end and i would like to replace the bearings too.i have found these:
http://cgi.ebay.com/ebaymotors/KOYO-Rear...dZViewItem
and they say it is for the AE86 kuoki version(1985-87) but i have an a zenki(1983-85) i wanted to ask you all if they are going to fit in my diff.thanks a lot
03-28-2007, 12:15 AM
i think the half-shafts (axles) are different diameter between kouki and zenki - so i dont think so. not sure though..
03-28-2007, 08:16 AM
The spline at the end of the half-shaft is different size but the bearing's inner diameter is the same on both axles, as is the axle housing itself. So those bearings will work on both zenki and kouki.
I checked it from EPC as well - the Toyota part number for the AE86..GT bearing kit is 04421-14010 and fits cars manufactured between 8308-8707.
03-28-2007, 12:06 PM
aha thnx. Thumbs up!
03-29-2007, 11:48 PM
thanks a lot folks for your help
  Need help identifying this! takumi_mt 4 1,743 04-05-2024 09:17 AM
Last Post: takumi_mt
  TRD ECU need help ps13michi 5 5,117 02-18-2022 10:42 AM
Last Post: ps13michi
  Bluetop Engine Rebuild multiple question Goal 150-160hp Hanzo 16 11,687 04-19-2021 10:08 PM
Last Post: Hanzo
  Rear Differential rebuild chenfon 10 11,596 11-20-2020 12:18 AM
Last Post: totta Crolla
  AE86 4A-GE 16v engine harness rebuild FanIsHere 7 11,976 01-17-2020 08:04 PM
Last Post: Project D
