Need help with the air sensor
09-07-2007, 05:03 PM
Yesterday I went for a run, and when I shut down the car, (it has a turbo timer) didn’t idle, so I open the air filter and try to crank the car, but the flap inside the sensor was not working, ANY IDEAS OF WHAT THE #@#@!# Is happening with that sensor, do u have ideas on how to replace the sensor with a better technology?? How can I adjust the internal flap inside the sensor???
Regards ![]() ![]() ![]() ![]() Sergio |
09-07-2007, 05:12 PM
20V TURBO * I FORGOT
09-07-2007, 08:39 PM
? air sensor ? is it afm ? please can you post a picture ? Or is it you tps ?
09-07-2007, 09:25 PM
09-08-2007, 03:09 AM
ANY IDEAS HOW TO QUICK FIX THE PROBLEM ?
09-08-2007, 11:22 AM
I dont quite get it.. you have a turbo timer, but the engine wont idle when you switch the engine off (when the turbo timer should take over)? If it idles when you run it, it should idle with the timer too, maybe you wired it incorrectly, causing some vital thing to switch off (ignition/fuel). As I understand it, a turbo timer is nothing more than a delay between the moment you turn the ignition key to off, and the moment that the ignition is actually turned off.
Need help identifying this! | takumi_mt | 4 | 1,197 |
Fitting Air Con (No PS) to LHD AE86 | pack | 7 | 4,425 |
01-07-2024 11:36 AM Last Post: CCB |
Lambda sensor wiring | sam3007 | 10 | 4,756 |
TRD ECU need help | ps13michi | 5 | 4,271 |
Air Cleaner Assembly | Hama86 | 7 | 9,611 |
10-29-2018 03:28 AM Last Post: Hama86 |
