Need new battery it seems...
09-03-2006, 09:53 PM
Rats,
I'm getting good at pushstarting my car hehehehe..
Since yesterday I keep running into my car not starting. I still got power but not enough to make the starter go round, it tries but dies.... Yesterday I still had that after a drive when I park the car I could start it right up again but after it stood still for 15 mins no joy. But since today even after a drive it just wont start.
Tonight I had the battery out of the car and in a charger for about 4 hours but that didn't do any good so I guess that rules out a problem with the alternatorBig Grin
So its either the battery or the starter itself. Anything I can check to make sure its the battery that's gone? I need to buy a new battery anyways cause I need one for the RX7 but rather make sure I need one first...
09-03-2006, 10:46 PM
Mux213 Wrote:So its either the battery or the starter itself. Anything I can check to make sure its the battery that's gone? I need to buy a new battery anyways cause I need one for the RX7 but rather make sure I need one first...
Borrow mine first, just like when my battery was bad! Big Grin Big Grin
[Image: AEU86 AE86 - Need new battery it seems...]
09-03-2006, 11:24 PM
no problem to check it with my battery. Let me know if i can help you
09-04-2006, 01:59 AM
Have had same sorta problem, replaced battery but turned out to be bad starter. Bearing on rotor had gone bad(totally gone), there where small peaces of metal everywhere inside. So rotor had alot of play and touched the stator Huh
But you have to take it out to actually check.
Disclaimer: Any errors in spelling, tact, or fact are transmission errors.
09-04-2006, 09:57 AM
Put in new battery this morning, car started up just fine... so if it doesn't die again within a week or so I'm pretty sure it was the batteryBig Grin
So this old battery is going into the RX7 for a little while, I only need it to test the electrics (windows/lights/etc) and it still gives enough power for thatBig Grin
09-04-2006, 04:53 PM
My alternator is dying. It's only charging 11.8V at the moment. Might fix that tomorow.
09-05-2006, 11:07 AM
congrats Muxie!! Hope to see you coming to the BBQ with a full battery and a working engine Smile
09-06-2006, 04:40 PM
ZaX Wrote:My alternator is dying. It's only charging 11.8V at the moment. Might fix that tomorow.
Diode bridge died on my alternator.
I've put the alternator from blue spare parts car. It drives again and I have a smile on my face.
09-06-2006, 07:39 PM
Good good zax!
09-06-2006, 07:40 PM
and 2 hours later my car dies again.
I think problem lies in damaged wirieing harnes, because they got burned when car was on fire after drifting incident.
One of wires that goes form battery has completely burned isolation, acrost the distributor to the injector loom.
I startet the car again and alternator is not chargin so I'm very sad.
I will have to remove MAP wireing harness from blue parts car to silver one. I hope this alternator did not die because I don't have any more spare ones nor the money to fix that in next 2 months. Sad
  AE86 Battery specs hachirokuGTV 9 16,296 03-13-2020 04:16 PM
Last Post: Power_uP
  Quick question for those who have relocated their battery.. Jezza_hr 10 10,796 03-06-2014 12:38 AM
Last Post: rene
  Making new wiring harness from scratch, need help Jimmi The Kid 13 25,452 02-10-2014 09:01 PM
Last Post: Jimmi The Kid
  Jap battery in uk? phill 92 3 6,195 11-06-2012 11:00 AM
Last Post: phill 92
  battery question Petros AE86 5 6,959 10-17-2012 08:15 PM
Last Post: JGeorge
