New camshafts for 4age -> 160hp
12-30-2005, 03:49 PM
harkes Wrote:So, to summarize:
1. Remove TVIS
2. Flow inlet manifold and head
3. Mill head for higher compression (? : ??)
4: Install camshafts with ??? timing and max 8,9mm lift
5: Install 4-2-1 exhaust
6: Re-mapped ECU
The limit for modifying my current engine is around 1000£. I can buy a used rally engine (ITB, Unichip, Exhaust, 302 - 8,9 cams) with 160hp for around 1500£...
- Niels
Basically yes, if your running std pistons and valve train then you are limited to lift potential.
£1000 wont get you very far i'm afraid, it'll buy you the components, but you'll probably have to install and fit everything yourself.
Old racing engines can be good, but they can be crap (hence them being sold). They are thrashed, and sometimes not built well at all. I personally wouldnt get an engine running ITB's unless it was running a standalone ecu, running a piggy back system on an ITB inductions setup, with large overlap period cams = screwed map signals and poor performance and massive lope.
12-30-2005, 06:03 PM
BenR Wrote:. I personally wouldnt get an engine running ITB's unless it was running a standalone ecu, running a piggy back system on an ITB inductions setup, with large overlap period cams = screwed map signals and poor performance and massive lope.
I´m struggling on this same issue....
I have considered running piggyback/Apexi AFC to control my 20v itb setup.
But i guess since i´ll be running 268 Shrick cams it will be an impossible task, or maybe just an horrible experience!?
This will be mounted on a 7AGE bottom with smallport head and pistons.
My evil Red/Black Panda
My current JDM AE86 project
12-30-2005, 08:46 PM
BenR Wrote:twin 40's are pretty small nowadays and you wont be making much more than 140-150bhp on them with the chokes at their largest size, then you will get low velocity problems as the signal strength is low.
I don't know the specs of the camshafts, but if you are able to decently remap or use a good piggy back system (NOT an SAFC etc) then it could be a nice drive. All our super production based 86's ran on the std type inlet manifold with about 160-170bhp back in the late 80's.
http://home.att.net/~jroal/carb.exe
This is a simple tool for such calculations. Also can compare single TB and 4 TB setup CFMs.
http://www.club4ag.com/faq%20and%20tech_...04A-GE.htm
This is also usefull article about 4AGE and carburators. Seems that 40s will be good choice for 3000-8000RPM range in 1.6 engine like 4AGE.
12-31-2005, 08:39 AM
They work and run, but it jsut becomes a terrible pain. In most cases i've seen where they come over from japan, the ecu is simply dumping fuel in non stop with no effort for metering it.
  Bluetop Engine Rebuild multiple question Goal 150-160hp Hanzo 16 10,342 04-19-2021 10:08 PM
Last Post: Hanzo
  Which new bearings for ae101 4AGZE crankshaft&connecting ditn 4 7,433 10-31-2013 06:04 PM
Last Post: ditn
  4AGE camshafts (again) Alex170984 26 31,077 03-19-2013 02:41 PM
Last Post: Alex170984
  What camshafts would be nice? PatrickAE86 44 42,755 08-25-2010 01:06 PM
Last Post: Uzelac
  lowering - adj. panhard rod & rca's & panhard bushin Apolan 8 7,723 05-24-2009 10:20 AM
Last Post: Apolan
User(s) browsing this thread:
