Which new bearings for ae101 4AGZE crankshaft&connecting
10-29-2013, 01:48 PM
Im currently rebuilding my ae101 4agze and i want to use new oem bearings for crankshaft & connecting rod
Im a bit confused to which mark i need to use Huh
Im thinking
crankshaft MARK 3 11701-16010-03
connecting rod MARK 1 13041-16071-01
is this correct? Smile
11711 BEARING, CRANKSHAFT
11701-16010-01 MARK 1 5 $18.56
11701-16010-02 MARK 2 5 $18.56
11701-16010-03 MARK 3 5 $18.56
11701-16010-04 MARK 4 5 $18.56
11701-16010-05 MARK 5
13041 BEARING, CONNECTING ROD
13041-16071-01 MARK 1 4 $14.87
13041-16071-02 MARK 2 4 $14.87
13041-16071-03 MARK 3
10-29-2013, 03:02 PM
You have to actually measure all the gap's... Follow the manual!
10-30-2013, 01:03 AM
If using genuine bearings, have a look at your crank, conrod and block markings, there will be numbers stamped into it.
for example if you doing a main bearing there will be a number on the crank and one on the block, and they will match up to a bearing size in the chart.
All descibed in the manual. I´d still plastigauge them anyway.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
10-31-2013, 06:04 PM
ok thanks for the help Smile
  Crankshaft stamping Blaze0010 6 4,519 06-10-2024 10:16 PM
Last Post: Blaze0010
  20v BT - which oil pump? Mylesmck 4 5,915 06-21-2022 04:51 PM
Last Post: pack
  Question on Rod Bearings mister86 3 6,252 03-19-2020 03:46 AM
  Emergency help find store with bearings france Allexz 5 7,552 09-12-2019 03:24 PM
Last Post: Allexz
  AE101 4AGZE workshop manual bozu 1 8,954 04-04-2017 10:52 PM
Last Post: hachirokkos
