Question on Rod Bearings
03-18-2020, 02:12 AM
Hey everyone, I have a question that I hope you can help me. I am replacing my rod bearings and it looks like I have the wrong ACL ones. I have the early type 40mm crank with the 18 pin size, not the 20 size.
So I am trying to figure out which bearings (ACL, King, etc) is the correct one to get because the set I purchased from MRP doesnt work. Let me know. Thank you! |
03-18-2020, 05:53 PM
Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-18-2020, 06:01 PM
(03-18-2020 05:53 PM)oldeskewltoy Wrote: Any chance you have access to Rockauto?? I do. which one do I need to get? or any of them? |
03-19-2020, 03:46 AM
(03-18-2020 06:01 PM)mister86 Wrote:(03-18-2020 05:53 PM)oldeskewltoy Wrote: Any chance you have access to Rockauto?? Toyota bearings are also still available.... what I would do... is get the crank journals measured before you buy bearings... all the journals... - Why? you might just order (ask your machinist first) oversize bearings and machine the crank to fit the tolerance you want. Tolerances are in the FSM Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
Emergency help find store with bearings france | Allexz | 5 | 5,057 |
09-12-2019 03:24 PM Last Post: Allexz |
Diff bearings | izanagi | 11 | 16,611 |
07-05-2014 07:29 PM Last Post: assassin10000 |
Top mount bearings | totta Crolla | 1 | 3,890 |
01-22-2014 11:33 AM Last Post: totta Crolla |
Which new bearings for ae101 4AGZE crankshaft&connecting | ditn | 4 | 7,433 |
10-31-2013 06:04 PM Last Post: ditn |
Diff bearings | Hachi-man | 4 | 5,583 |
11-14-2012 07:04 PM Last Post: McKenney |
