New engine on the road - 0-220 (165)kmh
01-11-2014, 05:33 AM
http://youtu.be/VA_Jw6YosR4
Things happen fast on the speedo but running the IS200 gearbox you have to subtract ~25% for actual GPS-KMH. |
01-11-2014, 09:12 AM
it kills!!mate!nice job
4age 16v to FR 20VT |
01-11-2014, 10:13 AM
Now that is one nice 4age !
Is it a red top small port ? Cams ? My guess Kent T1604 ? Management ? Cheers, An analogue brain in a digital World |
01-11-2014, 11:35 AM
totta Crolla Wrote:Now that is one nice 4age ! http://www.aeu86.org/viewtopic/small-por...ht=#149659 PS: catcams has changed their cams over the years so unfortunately there is no more info to be found on the old sets, unless the person who bought it still has the spec sheet that came with them. AE86 ex-daily |
01-11-2014, 03:04 PM
@Bean Bandit
Thanks for linking to my (rather short) build post. Yes sweet engine...but max torque @ 6100 is a little high so the plan is to convert to 1NZ valve lifters and get a less aggressive cam with +10,5mm lift. Engine has now run ~1000km so time for an upgrade |
01-11-2014, 03:44 PM
do you have a dyno graph - even if we don't know the exact spec of your cams. Hopefully during this summer I'll have my engine together and tuned too. Still considering to go with different cams but have to see where I am right now.
On another note peak torque is not necessarily bad at 6k if you get a good percentage of it already lower down. For driveability the area below the torque curve is more crucial than final numbers. AE86 ex-daily |
01-11-2014, 10:29 PM
01-12-2014, 07:51 AM
Torque and power..
01-12-2014, 08:54 PM
very nice........ glad it all worked well... and it is FAST......
Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-24-2014, 03:50 PM
My reaction to this movie:
I JUST JIZZED IN MY PANTS THE SECOND YOU HIT THE GAS !! Build your dreams. Ford Puma 1.7 Zetec-s Daily Toyota AE86 Levin Coupe "Jinxy"- Dreamcar Mitsubishi sapporo - bosuzoku project |
AE 86 0N THE Rolling Road and links on work done | williep12 | 3 | 5,604 |
10-15-2011 09:01 PM Last Post: williep12 |
User(s) browsing this thread: 17 Guest(s)
