New wheelbearings, why so expensive?!
01-29-2007, 07:14 PM
HI!
i´m gonna install my new lsd in the next few weeks and i think i will get a set of new wheelbearings after removing the driveshafts, but why are they so expensive. oem toyotas costs in austria over 200euros (1 peace) and aftermarket 105 euro, is there a way to get cheaper ones? |
01-29-2007, 07:31 PM
Find a Koyo distributor and order DAC 357245 CWRS. It replaces the original AWRS.
In Denmark i can get it for 500 dkr, thats around 70E Youtube Myspace and I´ll Google your Yahoo |
01-29-2007, 07:43 PM
hmmm maybe i find a dealer in germany,...
01-29-2007, 07:45 PM
Should be possible, its not a special bearing only used for toyotas :wink:
01-29-2007, 07:50 PM
thanks for you help, i hope the part number is right, and they will fit on my hachi
01-29-2007, 07:55 PM
Well, the original bearing on my Zenki was a DAC 357245 AWRS (35=inner diameter, 72=outer diameter, 45=bearings thickness) and i called our local bearing distributor that told me that "AWRS" was replaced with CWRS.
But take a look at the old bearing or take the mearsures before ordering a new. If your car i newer than 1985 it might have a slightly different bearing (caused by thicker axels) Youtube Myspace and I´ll Google your Yahoo |
01-29-2007, 08:44 PM
i got a zenki model, 84 for sure
01-30-2007, 12:17 AM
ebay... search under "AE86" and "bearings"... they are FREQUENTLY on there. about $65 to $70 (US dollars) per bearing
Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-01-2007, 12:27 AM
If you have Beck Arnley parts available in your area, you can use those as well, they're just re-boxed KOYO bearings.
BA Part number is 051-3884 (Includes bearings and retainers) |
02-01-2007, 02:50 AM
these cost about 80 australian $$$ and thats for 4 cornors!!!!
20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 1,315 |
Exhaust has white smoke coming out and I dont know why... | mister86 | 3 | 4,493 |
01-19-2020 12:06 AM Last Post: Power_uP |
Why Zenki and Kouki colour difference | MIGGZFSU | 10 | 18,841 |
04-23-2017 09:16 AM Last Post: MIGGZFSU |
DIY: a quick outline on why & how to set pinion angle. | assassin10000 | 9 | 18,109 |
Why Manual Steering Rack ?? Power Steering Removal | juantonwan | 26 | 42,791 |
