Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP
02-08-2020, 11:31 AM
(02-07-2020 02:36 PM)Project D Wrote:(02-07-2020 01:37 PM)The Doctor Wrote: Do you really need all that?One of my friend tried that, almost blew his engine up... I stand corrected... ![]() I meant afm indeed, but typed it wrong. But I was wrong all together. "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
02-10-2020, 02:29 PM
(02-07-2020 06:33 PM)mister86 Wrote: I really don’t have a budget, and can do anything. I don't want to be rude, but if you want a clean build maybe start where it matter the most. Unless it's just for bragging right at car meets. You must have a budget, unless your daily drive is a Bugatti and $10000 is pocket change for you. Just the rebuild alone can be pretty expensive. (gaskets, seals, bearings, surfacing the head and the block, valve job, etc...) And while it's open you might as well start on the internals. For the major parts I would say oil pump, cams, pistons and ECU + injectors to make it run properly. Then header and exhaust (mind you the header itself is not a big restriction) And finally ITB if your budget still allow it. |
02-10-2020, 06:39 PM
(02-10-2020 02:29 PM)Project D Wrote: I don't want to be rude, but if you want a clean build maybe start where it matter the most. Unless it's just for bragging right at car meets. I agree and would go even further. If there's no budget, pay for the services of someone who is already a professional engine builder and let them go nuts with the engine. Also, if you don't already know what you're doing with ITBs then you won't gain much over the popular carburettor setups, perhaps consider that. I admit that its been a long time since I was involved with any tuning. But the last time I knew someone go with ITBs and a standalone ECU, they had to spend a lot of time and money on a rolling road to get everything set up correctly. |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,754 |
AFM to Map Conversion | ps13michi | 3 | 3,457 |
Bluetop Engine Rebuild multiple question Goal 150-160hp | Hanzo | 16 | 9,903 |
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 4,365 |
Bluetop on turbo | leon205gti | 7 | 8,126 |
09-20-2016 09:17 PM Last Post: leon205gti |
