Newbie with some questions!
02-22-2006, 11:32 PM
I am newbie, with a MG Midget with 4AGE installed in it. See Project section. I have a few questions:
I removed the exhaust manifold to replace the gasket, i had to remove the distributer to get it off. Not alot of room in a midget. The distributer moved when it was off and the car wouldn't start, I played about with it until I got i running but I am not sure if the distributer is on in the right place. Any easy ways to check?
Cheers
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
02-23-2006, 09:08 AM
First: Welcome here...
Second: Do yourself a big favour and download the factory manuals (look in the sticky topics in the tech section).
Third: Although the manual also describes this: To get the distributor back in properly you need to line up a line on the shaft going in to the engine and a dimple in the bit right above that shaft (fixed bit)
It might be 2 lines or some other indicator depending on which type of distributor you have, but that is how it's done. Once you've lined up the marks, you have to put the distributor in, trying to keep it centered in it's range of adjustment.
Fourth: I would advise you to get a timing gun, find the location of the check connector on your loom, and set the timing to 10deg BTDC
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 3,064 05-26-2024 07:40 PM
Last Post: totta Crolla
  Windscreen stoopid(?) questions.... Mylesmck 7 1,589 04-30-2024 09:46 PM
Last Post: Mylesmck
  Brake Bias Questions mad.matt 10 11,948 01-03-2019 04:54 AM
  Ae86 newbie malflip1 12 12,580 02-10-2018 08:15 AM
Last Post: malflip1
  wider rear axle,track width,suspension questions ditn 6 9,284 10-18-2016 11:50 AM
Last Post: fantapants
