No replacement for displacement, right?
12-30-2012, 05:27 AM
I am curious about swapping a 22R into my '85 SR5, any thoughts?
12-30-2012, 07:14 AM
My thought, no. If you want Toyota displacement go UZ.
12-30-2012, 10:56 AM
And if you want to go V8, skip the UZ and go directly for the LSx.
/thread. A wheel to steer the front of the car A pedal to steer the rear |
12-30-2012, 01:12 PM
displacement in a Hachi???
![]() ![]() ![]() AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
12-30-2012, 08:34 PM
for the "purists" the only displacement replacement swap would be a Franken 7AG, or similar stroked "A" engine...
![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-30-2012, 10:51 PM
oldeskewltoy Wrote:for the "purists" the only displacement replacement swap would be a Franken 7AG, or similar stroked "A" engine... Yes, like an F20C :mrgreen: :mrgreen: :mrgreen: :mrgreen: AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
12-30-2012, 11:48 PM
F20c is not for purists...
12-31-2012, 01:19 AM
Well if you go V8, UZ it, light alloy block and even on standard management more than enough power. The assembly with a W58/ R154 is lighter than a similar LS combo and to keep the purist theme light is still the most important thing on an AE86!
Much better than F20c cause it has torque ![]() 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
12-31-2012, 01:35 AM
10kg lighter then an LS1 engine making 100+hp more and a shitload of torque, 50kg heavier then an F20C that makes 20 less hp. Jup, great compromise
![]() They are cheap though.. shame that the parts needed to plonk it into an AE86 aren't. A wheel to steer the front of the car A pedal to steer the rear |
12-31-2012, 02:00 AM
Hmmmm my 1UZ made 240WHP stock... then turbo made 500WHP, had it in a MKIV Supra. I would go for the 3UZ if I was to go UZ again...
Right hand to left hand | halu_aoi | 14 | 15,518 |
05-16-2013 03:15 AM Last Post: Rascal21 |
User(s) browsing this thread:
