No replacement for displacement, right?
12-30-2012, 05:27 AM
I am curious about swapping a 22R into my '85 SR5, any thoughts?
12-30-2012, 07:14 AM
My thought, no. If you want Toyota displacement go UZ.
12-30-2012, 10:56 AM
And if you want to go V8, skip the UZ and go directly for the LSx.
/thread. A wheel to steer the front of the car A pedal to steer the rear |
12-30-2012, 01:12 PM
displacement in a Hachi???
12-30-2012, 08:34 PM
for the "purists" the only displacement replacement swap would be a Franken 7AG, or similar stroked "A" engine...
12-30-2012, 10:51 PM
oldeskewltoy Wrote:for the "purists" the only displacement replacement swap would be a Franken 7AG, or similar stroked "A" engine... Yes, like an F20C :mrgreen: :mrgreen: :mrgreen: :mrgreen: AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
12-30-2012, 11:48 PM
F20c is not for purists...
12-31-2012, 01:19 AM
Well if you go V8, UZ it, light alloy block and even on standard management more than enough power. The assembly with a W58/ R154 is lighter than a similar LS combo and to keep the purist theme light is still the most important thing on an AE86!
Much better than F20c cause it has torque 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
12-31-2012, 01:35 AM
10kg lighter then an LS1 engine making 100+hp more and a shitload of torque, 50kg heavier then an F20C that makes 20 less hp. Jup, great compromise
They are cheap though.. shame that the parts needed to plonk it into an AE86 aren't. A wheel to steer the front of the car A pedal to steer the rear |
12-31-2012, 02:00 AM
Hmmmm my 1UZ made 240WHP stock... then turbo made 500WHP, had it in a MKIV Supra. I would go for the 3UZ if I was to go UZ again...
Right hand to left hand | halu_aoi | 14 | 14,974 |
05-16-2013 03:15 AM Last Post: Rascal21 |
