OST-017: Ed Sullivan it ain't!
04-10-2012, 06:35 AM
[Image: AEU86 AE86 - OST-017: Ed Sullivan it ain't!][Image: AEU86 AE86 - OST-017: Ed Sullivan it ain't!]
Although it might be considered a REALLY BIG SHOW.... in reality, it's my first race head... fitted with oversize(Atlantic size) valves.
More to come Big Grin
Dan -
04-10-2012, 08:06 AM
from another forum Wrote:Are you sure it's not a really big shew?
shew... show... one thing is for sure... no one but Ed... could deliver Ed's lines... like Ed :lol:
A few facts for those who like their numbers....
bore = 3.2680"
stroke = 3.0315"
Deck = .025"
gasket = .020"
piston volume = 9.5cc
So... for those who like to do this kind of math......what will his compression be with 36.25cc chambers? What will his compression be with 39.5cc chambers?
Dan -
04-10-2012, 06:04 PM
oldeskewltoy Wrote:So... for those who like to do this kind of math......what will his compression be with 36.25cc chambers? What will his compression be with 39.5cc chambers?
from another forum Wrote:With 36.25cc chambers, you're looking at around 13.7:1 compression.
With 39.5 you're looking at around 12.5:1.
Amiright?
Big Grin Big Grin Big Grin
yes you are VERY right......
13.7 would be massive, and since I was asked to supply a cylinder head with a desired static CR of 12.5 to 1, I'll need to "open up" this heads combustion chambers from a stock volume of 36.25, to a quite large 39.5cc.
The areas of enlargement are well outlined in black marker.
I've done this procedure once before.....
the top view shows before the chamber increase, the lower view shows after. Note the gap between chambers Wink
More to come.... Hurray!
Dan -
04-10-2012, 08:11 PM
With that CR I assume the cams will be around the 300 degree range
04-10-2012, 10:30 PM
With what pistons are these numbers ?
nice job by the way Thumbs up!
'87 levin coupé
04-10-2012, 11:27 PM
Bean Bandit Wrote:With that CR I assume the cams will be around the 300 degree range
Yes... I'm told Kelford 193HV-B. 300 max duration, 10.5mm maximum lift
PatrickAE86 Wrote:With what pistons are these numbers ?
slugs are custom - Arias pistons
Thanks.... but I've got a LOOONG way to go
from another forum Wrote:running a thicker gasket would make that much easier...(then opening the chambers to 39.5cc)
easier.... Big Grin
but this way I can absolutely guarantee that the chambers will be free of any and all machining remnants
Dan -
04-11-2012, 12:23 AM
A few facts.... this is the first head I've worked on that was previously worked on by another person. The head's owner asked me if I could accept this condition, and I agreed. I told the head's owner that I'd do what I know to work - based on my previous experience.
Before I get to working on the chambers, I decided to begin working the intake ports. The bowls (from the splitter on back) will be worked on after the O/S valves are installed - so for the sake of this posting, I'm talking about the port from the splitter to the manifold mounting flange
Below is intake port #3... in all photos... if you doubt it, just look @ the guides.
Remembering that this is an O/S valve head, I need as much room within the gasket as I dare.
It's not only the outer gasket surface matched, but the entire port has been pushed nearly all the way to the gaskets size :eek: :eek:
A bit of side by side perspective... port on left is #3 completely roughed out, on right is #4, has yet to be touched by me.
More to come Hurray!
Dan -
04-12-2012, 02:45 AM
oldeskewltoy Wrote:[Image: AEU86 AE86 - OST-017: Ed Sullivan it ain't!]
A slightly different perspective on the same 2 ports, this time from a more revealing angle
apologies for the less than perfect view of the crappy port, especially as the ported view is pretty clear... What can be discerned is the untouched port (right) has an amorphous blob in the lower right of the port, not seen(now removed) in the much clearer view of the ported port. Also note gasket fitment, the right hand port will give up about 1.5mm at the gaskets surface, but the interior gives up even more. The cross width of a standard smallport is about 44-46mm, the cross width of these ports is now between 48mm, and 48.25mm
The 4 intake ports are now mostly to size, there will be some changes as they are additionally blended after the O/S seats are installed
Dan -
04-12-2012, 02:46 AM
Before and semi-after. Well, as semi-after as I go before the O/S valves are fitted. The tops of the ports are now where they need to be for flowing the kind of volume Atlantic valves flow. Once the O/S valves are fitted I'll push out the bowls to meet the new seats. It will be at that time that the remainder of the port work will occur... in essence the lower portion of the ports will get worked @ that time.
Let me introduce you to our four semi-finished intake ports....
Port #1
Port #2
Port #3
Port #4
Dan -
04-12-2012, 11:43 PM
Did a bit of clean up.... usually this is the amount of material I remove from the entire head.... this time... just the intakes ports :eek:
I also was able to rework those guides too. In numerical order....
[Image: AEU86 AE86 - OST-017: Ed Sullivan it ain't!] < #1
[Image: AEU86 AE86 - OST-017: Ed Sullivan it ain't!] < #2
[Image: AEU86 AE86 - OST-017: Ed Sullivan it ain't!] < #3
[Image: AEU86 AE86 - OST-017: Ed Sullivan it ain't!] < #4
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,575 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 4,989 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 3,382 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 2,174 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 1,723 06-28-2022 09:17 PM
