OST-030: a case in point
05-07-2015, 09:29 PM
So with OST-031 now @ the machine shop getting its valve job and surfacing we delve back into OST-030
I've gotten the head back from the machine shop, they have provided a minimum resurfacing .003", to add to the previous clients report of a .008" resurfacing, the current surface is not quite @ .011, closer to .0102". This head is now 115.74mm thick, having had a total of .26mm removed. Typically with a 10 thou cut you can expect chamber volumes to drop to about 35cc, the deshouding adds about .4cc, to gain volume I had the valve seats machined an extra .003" to gain 1cc in chamber volume, this lowers the valve on the seat allowing for a bit more volume in the chamber. The valve tips were cat an equal amount so use of more common shims sizes is retained. ![]() So right now the chambers sit @ 36.4cc (1/10cc tolerance) ![]() oldeskewltoy;6155985 Wrote:All the cam journals look pretty much the same as this... The FSM(BGB) states the cam to journal clearance to be .035mm to .072mm, with nothing greater then .1mm ![]() Using the Plastigage PL-X - The PL-X range is a bit on the tight side for measuring the whole range of the cam to journal - a bit too small for perfect accuracy, but in this case it works adequately. ![]() This is one of the measurements, you can see it is quite a bit narrower then .045mm which is middle tight of the span in the FSM. By carefully surfacing the cam cap "feet" we can get this dimesion closer to the center of the specification ![]() Here is a 2nd journal going from a bit loose.... ![]() to middle of the spec ![]() Of course the worst one I didn't get a photo of, that was #5 on the intake side... farthest from the oil supply, it was so loose that most of the Plastigage thread was intact when checked, and it too was brought into spec. Now that the cam journals are all within tolerance, assembly can begin..... More to come..... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-08-2015, 03:48 AM
Showing off her angles....
![]() oldeskewltoy Wrote:Now that the cam journals are all within tolerance, assembly can begin..... The head and hardware are all laid out, #1 cylinder already has the valves in.... ![]() Now half assembled... ![]() sometimes during assembly you see something that you just don't like.... tossed the retainer on the left for the one on the right. There was no other damage, I just didn't like that kind of a flaw. ![]() Fully assembled... now whats left is setting the valve clearances, and getting it back to my client. ![]() More to come..... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-12-2015, 04:46 AM
Valves @ full lift...
Exhaust.... ![]() Intake... ![]() oldeskewltoy Wrote:Fully assembled... now whats left is setting the valve clearances, and getting it back to my client. ![]() Its packaged back in its case.... with the latch zip tied down... ![]() I heated the end of my punch a bit so I could get it to impress into the ziptie. All that is left on this is shipping back to my client.... Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-13-2015, 06:19 PM
Well done Dan, still impressive despite the fact that I've seen it so many times.
AE86 ex-daily |
05-24-2015, 05:45 PM
oldeskewltoy Wrote: Why I insist on insuring the finished product for its shipment back to it's owner...... ![]() I've been told the head itself did not sustain any damage... but this shows significant intrusion.... so when I say the insurance adds $20, or $30 to the return shipping cost... its just to COVER YOUR ASSets. Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-25-2015, 08:09 AM
Damn, I do hope he gets some cash back for the case. Some people just don't have any respect for the property of others.
AE86 ex-daily |
05-25-2015, 07:56 PM
(This post was last modified: 05-25-2015 07:56 PM by banpei.)
Whoa! Was that deliberate intrusion or just collateral damage by someone dropping the case from the third floor?
05-25-2015, 10:17 PM
(05-25-2015 07:56 PM)banpei Wrote: Whoa! Was that deliberate intrusion or just collateral damage by someone dropping the case from the third floor?I guess it was just bad handling/dropping it in the sort facility/delivery guy AE86 ex-daily |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 2,558 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 4,928 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,368 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 2,164 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,717 |
