OST-032: Skippy gets a head
05-12-2015, 05:15 PM (This post was last modified: 05-12-2015 05:15 PM by oldeskewltoy.)
Some of you know I've purchased a daily-able FX16 so I don't have to use Surreptitious(AE71) all the time...
[Image: AEU86 AE86 - OST-032: Skippy gets a head]
I named the FX "Skippy", and knew upon purchase that it didn't run.
This is what was found when the head was pulled... something broke, and eventually got embedded - see arrow
So.... OST-032 is Skippy's new head!
stripped and ready for cleaning........
Can anyone tell me why one chamber is already clean????
More to come..... Hurray!
Dan -
05-12-2015, 07:44 PM
Coolant leak into the cylinder ?
Leaking injector ?
05-12-2015, 08:20 PM
(05-12-2015 07:44 PM)totta Crolla Wrote:  Coolant leak into the cylinder ?
Thought the same thing Big Grin
Daily Beater: Civic EG5
Work in progress Car: AE86
05-12-2015, 08:55 PM
Leaking injector ?
normally these would be a great guesses....
But in reality this was a VERY loaded question - apologies Wink This chamber was the chamber used to make the chamber casting....
more to come..... Hurray!
Dan -
05-14-2015, 04:50 PM
Damn !
There I was thinking that if I post "because you cleaned it" you'd think I was taking the p*ss !
05-22-2015, 04:16 AM
(05-14-2015 04:50 PM)totta Crolla Wrote:  Damn !
can't win sometimes.... nature of carnival games Wink
So Skippy's head is back from cleaning and pressure checking. The chamber depths and the seat depth all look VERY good. There is some excess material that was left behind after the head was machined @ Toyota, that will all get cleaned up :thumbsup:
It measures just about what an uncut head is suppose to measure - easily within the .001" tolerance of this caliper
Work begins on chamber/bowls of #4 cylinder
More to come.... Hurray!
Dan -
05-23-2015, 02:28 AM
oldeskewltoy Wrote:Work begins
and continues....... Smile
@ cylinder #4....
deshrouding....
...and working the exhaust....
2 cylinders down,
2 to go.... more to come.... Hurray!
Dan -
05-27-2015, 03:04 AM
It's far easier to take the direct path......then the path with the bend [Image: AEU86 AE86 - OST-032: Skippy gets a head]
more to come....... Hurray!
Dan -
05-28-2015, 04:51 AM
oldeskewltoy Wrote:It's far easier to take the direct path......then the path with the bend [Image: AEU86 AE86 - OST-032: Skippy gets a head]
bends are gone......
Dan -
05-29-2015, 01:15 AM
Now that the casting has been massaged... It'll go off to the shop on Monday to get its 3 angle, and have the head surfaced.
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 4,014 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 8,088 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 5,535 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 3,658 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 2,944 06-28-2022 09:17 PM
