OST-034: Noir Crowning
08-06-2015, 05:27 PM
I got a request........
[Image: AEU86 AE86 - OST-034: Noir Crowning]
More to come.... Hurray!
Dan -
08-06-2015, 05:53 PM
Oh man.... sweet..!
08-06-2015, 06:19 PM (This post was last modified: 08-06-2015 06:21 PM by Bean.)
Is it just me or does the 16V benefit more from porting than 20V regarding flow benefits?
08-12-2015, 12:31 AM
(08-06-2015 06:19 PM)Bean Bandit Wrote:  Is it just me or does the 16V benefit more from porting than 20V regarding flow benefits?
lets see.......
the intake side.....
paper towel in exhaust port is acting as a "cork", remember these are used valves, in used seats, and stuffing the opposite port to the one being test allows for honest figures.
The numbers @ 28".......
Unported Intake -
  • .050 - 58.15
  • .100 - 110.87
  • .150 - 146.30
  • .200 - 168.30
  • .250 - 180.08
  • .300 - 186.65
  • .350 - 191.22
  • .400 - 194.10
Ported Intake -
  • .050 - 60.02
  • .100 - 114.30
  • .150 - 149.20
  • .200 - 177.33
  • .250 - 185.47
  • .300 - 192.33
  • .350 - 197.78
  • .400 - 202.35
There is a glaring error on one reading, can anyone find it??? I likely over adjusted one valve, What should it read (about/approximate)??
setting up to do the exhaust side
Unported Exhaust -
  • .050 - 32.45
  • .100 - 65.52
  • .150 - 90.95
  • .200 - 110.12
  • .250 - 122.80
  • .300 - 130.25
  • .350 - 135.48
  • .400 - 140.43
Ported Exhaust -
  • .050 - 35.38
  • .100 - 65.88
  • .150 - 93.73
  • .200 - 113.50
  • .250 - 130.63
  • .300 - 139.92
  • .350 - 146.33
  • .400 - 151.20
More to come...... Hurray!
Dan -
08-24-2015, 08:20 PM
Nearly a 2 week delay...
I had a talk with my client, he is hoping for an exhaust to intake flow ratio approaching 80%. This is going to be extraordinarily difficult because the stock Blacktop flows about 61%, and the first attempt at porting the exhaust side did improve things, now 67%, but a further gain of 13% seems a long goal at best.
My first attempt at porting the exhaust was limited because I didn't have a gasket to know where my edges were, and I didn't want to port beyond the gasket, for doing that would cause serious flow issues. So the initial porting on #4 exhaust was from about 33.6 to about 33.7, because not knowing the exhaust gasket left me a bit in the dark.
My client sent me the OEM gasket
Port on far right is #4, even with the gasket in the "down" position, there is still some room available in the port roof, and room all the way around the port.
So now that I had a gasket, work begins on #2 exhaust port. Redline is the gaskets edge.
A bit more dramatic....
The stock Blacktop gasket outlet is 36mm. Port #2 is now out to 34.8mm
Later this week I'll get this on the bench and see what if any improvement there is over the first numbers.
More to come........ Big Grin
Dan -
08-26-2015, 11:53 AM (This post was last modified: 08-26-2015 11:53 AM by banpei.)
That's a lot of area you gained! Huh
08-27-2015, 09:47 PM
oldeskewltoy Wrote:[Image: AEU86 AE86 - OST-034: Noir Crowning]
Ported Exhaust (#4 - port on left) -
  • .050 - 35.38
  • .100 - 65.88
  • .150 - 93.73
  • .200 - 113.50
  • .250 - 130.63
  • .300 - 139.92
  • .350 - 146.33
More to come...... Big Grin
"New" exhaust port readings, #2 port - on right
  • .050 - 34.98
  • .100 - 65.03
  • .150 - 93.67
  • .200 - 113.32
  • .250 - 131.88
  • .300 - 142.53
  • .350 - 150.92
The reason testing stopped @ .350 was my client is limited to 9mm of lift (.354")
So now the intake @ .350" is @ 197.8cfm, while the exhaust is now @ 150.9, the exhaust to intake flow ratio is now a tick over 75% at peak lift, and over the lift range the exhaust to intake ratio is now about 71.5% (was 61%)
More to come..... Hurray!
Dan -
09-04-2015, 01:46 AM
a few views of working the exhaust side.....
minimizing the guide boss, and tapering the guide - both to minimize their effect on the outgoing exhaust flow
reshaping the exhaust port - maximizing flow
3 ports down.... one to go
more to come..... Hurray!
Dan -
09-08-2015, 06:33 PM
Dan -
09-09-2015, 01:36 AM
Now to finish up the intakes and the chambers....
More to come....... Hurray!
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,261 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 4,119 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 2,934 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 1,886 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 1,498 06-28-2022 09:17 PM
