OST-056: Nasty.....
05-01-2019, 07:01 PM
OST-056: Nasty.....
[Image: AEU86 AE86 - OST-056: Nasty.....]
Another first gen 4AG head, this one is a bit Nasty....
Btw, here is a photo showing the difference between a 1st gen TVIS head, and a 2nd gen TVIS head. A first gen is what came on the AE86, the 2nd gen is later
So, getting back to OST-056, the head is stripped, cleaned(?), and pressure checked. Once back, I deburr the casting
more to come...... Hurray!
Dan -
05-06-2019, 07:12 PM
OST-056: Nasty.....
from another forum Wrote:
oldeskewltoy Wrote:Btw, here is a photo showing the difference between a 1st gen TVIS head, and a 2nd gen TVIS head. A first gen is what came on the AE86, the 2nd gen is later
I have to wonder if Toyota had the MR / FWD mounting in mind when they (or Yamaha) designed the 4A-GE. I have one each of the big port heads and noticed this difference.
I've yet to see a Toyota application that uses that mount...........
Work on the head proceeds.....
"Building" the intake side - blending the seat, bowl, and port Wink
also working the exhaust side
Dan -
05-10-2019, 09:05 PM
OST-056: Nasty.....
oldeskewltoy Wrote:[Image: AEU86 AE86 - OST-056: Nasty.....]
A facebook "viewer" asked if my work fits the stock gasket... I assured him it does......
Further progress... 3 down... 1 to go
more to come....... Hurray!
Dan -
05-11-2019, 05:16 PM
OST-056: Nasty.....
AE92
05-12-2019, 01:47 PM
OST-056: Nasty.....
Dan
I believe best practice is to match the top of the exhaust port with the header gasket [highest flow area] and leave the step mis-match at the bottom of the port for anti-reversion?
Dave W
05-14-2019, 02:00 AM
OST-056: Nasty.....
Project D -
from another forum Wrote:I'm sorry I derailed the topic with this, but I guess we all learn something new every day. And I always love to see your work!
OK, here are some better pics. I had pulled all of the timing covers for my (someday, someday, someday) engine build, along with that small "cam bracket."
^ Bracket looks smooth in parts because I've been taking off the casting lines & imperfections, so that I can get it powder coated along with other parts.
oldeskewltoy Wrote:After learning about AE92 the timing cover......
good lesson(for everyone)... even if you think you know it all....... you don't
(05-12-2019 01:47 PM)Dave W Wrote:  Dan
Dave W
There isn't much to work with... most of my improvements take place inside... but on some heads..... that is why I worked with SV2 to help design the copper exhaust gasket - http://www.sv3power.com/store/index.php?...cts_id=217
Not only is it bigger, but part of the design was moving the bolts holes down (or exhaust ports up) by .020"
How it looks/fits....
But this head isn't going to see that much exhaust port work....
more to come.... Hurray!
Dan -
05-14-2019, 10:53 PM
OST-056: Nasty.....
Dave W
The pictures are taken with the head upside down Wink
Sent from my MHA-L29 using Tapatalk
05-17-2019, 12:15 AM
OST-056: Nasty.....
Dave W
ahh, I'm sorry I thought the ports being upside down was obvious... my apologies....
back from the machine shop wearing a new 3 angle, and back cut intake valves....
next, checking chamber volumes...
So if I want chambers down to 36cc, how much should I have machined from the head???
Dan -
05-17-2019, 12:47 AM
OST-056: Nasty.....
It's very late so my math might be off but I think about 1.5 thou (inches) sounds wrong but that's all I can come up with right now. I'm rusty with my numbers and a bit tipsy.
05-17-2019, 05:52 PM
OST-056: Nasty.....
(05-17-2019 12:47 AM)Bean Wrote:  It's very late so my math might be off but I think about 1.5 thou (inches) sounds wrong but that's all I can come up with right now. I'm rusty with my numbers and a bit tipsy.
well, about .008" is about 1cc(+ or -), so @ .6cc over, that would be about .005"
and that's how much I had it machined.....
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,387 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 4,444 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 3,115 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 2,003 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 1,584 06-28-2022 09:17 PM
