OST-058: "Q"
09-28-2019, 05:14 PM
OST-058: "Q"
![]() more to come...... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-28-2019, 08:41 PM
OST-058: "Q"
![]() ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
10-01-2019, 12:12 AM
OST-058: "Q"
(09-28-2019 08:41 PM)banpei Wrote: Not a whole lot going through my mind....... ![]() ![]() Recently I've acquired 5 20V 4AG heads. Two Silvertop, and three Blacktop ![]() One of the Blacktop heads went to a client in Indiana, this head is #2 from that lot.... and it is available.... ![]() disassembled, ready to get cleaned ![]() more to come.... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-01-2019, 08:26 PM
OST-058: "Q"
the head came back pretty clean...
This was the first 20V head I spent any time on deburring the casting flash ![]() Most of the casting flash was around the spark plug tube supports, and in the end areas. Some of the area are purposefully cast with a ledge, those areas stand out around the exhaust side bucket cylinders More to come...... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-03-2019, 03:07 AM
(This post was last modified: 10-03-2019 03:07 AM by oldeskewltoy.)
OST-058: "Q"
and so it begins.... biggest thing on a Blacktop head is core shift... you can kind of see it in top photo's short radius as it isn't centered
![]() Chamber #2 on top, chamber #1 on the bottom.... You can also see where I've done blending around the valve seats more to come...... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-03-2019, 05:27 PM
OST-058: "Q"
working the bowls to correct the core shift, and to create "gentle" short radii.....
10-04-2019, 01:12 AM
OST-058: "Q"
2 down... 2 to go....
10-14-2019, 06:21 PM
OST-058: "Q"
with the port work finished, its off to the machine shop to get its valve job, and re-surfacing
![]() more to come..... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-22-2019, 06:47 PM
OST-058: "Q"
back from its valve job(ain't those back cuts purdy..... ), and re-surface... ready for re-assembly.
![]() more to come.... ![]() PS... this head still needs a new owner....... Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 2,564 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 4,947 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,370 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 2,166 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,718 |
User(s) browsing this thread:
