OST-070: 7AGE for an N2 Levin
11-24-2020, 08:39 PM
Post: #31
TRD make a 0.4mm (compressed) one in case you ever need a thinner one
![]() AE86 ex-daily |
11-28-2020, 11:47 PM
(This post was last modified: 11-28-2020 11:49 PM by oldeskewltoy.)
Post: #32
(11-24-2020 08:39 PM)Bean Wrote: TRD make a 0.4mm (compressed) one in case you ever need a thinner one Not doubting you... but I just did a search on TRD Japan... and I can't find ANY 4AG parts listed......... This is an archive.... https://www.trdparts.jp/parts/archive/pa...a-g16.html Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
11-29-2020, 04:39 AM
Post: #33
TRD don't make anything anymore for the 4AG...
11-29-2020, 10:14 AM
Post: #34
(11-28-2020 11:47 PM)oldeskewltoy Wrote:(11-24-2020 08:39 PM)Bean Wrote: TRD make a 0.4mm (compressed) one in case you ever need a thinner one yeah my brain let me down - it's 0.5 P/N:11115-AE824 I bought mine 10 years ago through perfectrun, was still in stock then now sitting on my shelf in the workshop back in Switzerland AE86 ex-daily |
12-22-2020, 08:00 PM
Post: #35
Time to get the belt on and set cam timing.
But first we have a small problem to deal with... instead of a 116 tooth timing belt, I ended up with a belt with 119 teeth.... ![]() ....someone put the wrong belt, into the right box ![]() so once I got that settled, setting cam timing can begin.... it begins with KNOWING TDC. I use a piston stop, and determine exact TDC. Once TDC is determined, I move on to the cam card. ![]() I take the cam centerlines and mark them on my timing wheel ![]() and then adjust each camshaft so the cams centerline lines up with the respective marks on the timing wheel ![]() Note: finding the centerline of the cam is kind of like finding TDC on the crankshaft, to determine the exact centerline I use a few degrees on other side of the lobes peak to determine the actual center. Now that the cams are set according to the cam card, the timing cover, and trigger kit gets fitted. ![]() more to come.... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-22-2020, 10:46 PM
Post: #36
Not sure exactly why but I just love your tarp background pictures. They look a big step up in quality - well done.
The close up one of the cam wheels could be straight from a commercial. Maybe it's just the bokeh effect but whatever it is keep doing it ![]() AE86 ex-daily |
12-22-2020, 11:15 PM
Post: #37
I hope you dind't have to count all teeth of the cambelt to figure out it was the wrong one.
12-28-2020, 05:27 PM
Post: #38
(12-22-2020 10:46 PM)Bean Wrote: Not sure exactly why but I just love your tarp background pictures. They look a big step up in quality - well done. ![]() (12-22-2020 11:15 PM)banpei Wrote: I hope you dind't have to count all teeth of the cambelt to figure out it was the wrong one. I did.... no other way. and now fitting the TecArt's ITB kit........ ![]() On top is the vacuum collector, and the fuel rail is under - yep, the injectors spray up. Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-28-2020, 10:59 PM
Post: #39
(12-28-2020 05:27 PM)oldeskewltoy Wrote:That's painful.(12-22-2020 11:15 PM)banpei Wrote: I hope you dind't have to count all teeth of the cambelt to figure out it was the wrong one.I did.... no other way. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
01-05-2021, 09:41 PM
Post: #40
Packed up.....
![]() and on its way back to the client....... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 2,898 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 5,804 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,886 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 2,473 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,969 |
