Oil Temperature Gauge Substitute
02-09-2007, 10:03 PM
Who here has used a Water Temp Gauge as an Oil Temp Gauge? Any insights on why this would or wouldn't work are welcome and useful for people other than myself i'm sure.
[Image: AEU86 AE86 - Oil Temperature Gauge Substitute]
"Strictly All Things 86"
02-09-2007, 10:06 PM
Cant see why it shouldnt work, both of my gauges uses the same sort of temp. sensor...
02-09-2007, 10:21 PM
Knudsen Wrote:Cant see why it shouldnt work, both of my gauges uses the same sort of temp. sensor...
my thoughts exactly, but i'm of the opinion of looking both ways before crossing the road Wink
i appreciate it Knudsen
02-21-2007, 01:13 AM
Oil temperatures are usually higher than water temps, so the gauge might go off scale.
02-21-2007, 07:54 AM
A fair point, Ferret, but there is the question of the sensors themselves - if they emit the same signal on the same t°, then you are absolutely right...
02-25-2007, 07:14 AM
Ferret Wrote:Oil temperatures are usually higher than water temps, so the gauge might go off scale.
true and also, the water temp gauge may say "water temp" on it and that'll be annoying. Smile
02-25-2007, 02:40 PM
domi Wrote:A fair point, Ferret, but there is the question of the sensors themselves - if they emit the same signal on the same t°, then you are absolutely right...
I assume that the water gauge sender is used.
If a different sender is used, then the gauge won't read accuratly.
  EUDM gauge cluster banpei 22 5,588 08-15-2023 10:48 PM
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 8,024 12-06-2017 06:48 PM
  Analog gauge cluster tech Ivan141 33 44,066 01-31-2016 11:06 PM
  Original gauge with universal fuel sender Komba 4 6,640 01-05-2015 03:27 PM
Last Post: Komba
  trans oil, lsd oil change Apolan 9 17,595 10-01-2014 03:57 PM
