Oil cooler -> low oil pressure
03-28-2011, 06:12 PM
assassin10000 Wrote:Where is the sensor located?
Andrew
Jan Pedersen Wrote:Stock sensor position.
Not sure about yours... but I've never seen a stock oil temp switch anywhere on the 4AGE engine, in fact I had to add it to mine
[Image: AEU86 AE86 - Oil cooler -> low oil pressure]
Hmmmmm, another question for you.... is the oil pressure low when warm, but below 150 degrees? I'm just wondering if you have another problem being masked by the cooler
Dan -
03-28-2011, 09:19 PM
I thought he meant the pressure sensor Smile
Without the cooler I get 5.25 bar when revved cold or warm. With the cooler I got 2.5 warm and 3.0 cold when revved.
03-28-2011, 10:21 PM
The smaller the diameter, the faster the oil flows, producing more pressure loss due to the hose friction.
I think you're problem is not "hose related", but curves and other accessories create pressure loss.
03-29-2011, 09:30 AM
What dia is the hose? Is it possible to mount the Mocal plate backwards?
Got good pics of your setup you can post in here?
Andrew
03-29-2011, 08:33 PM
~9 mm but fittings are smaler. The mocal plate can only be mounted one way. No pics, sorry...
I'll go up to 12mm hoses as I'm sure thats the problem. I convinced myself at least Wink
03-30-2011, 08:08 AM
I figure that 12 diameter hoses should reduce the pressure drop by around
60% from what it has been.
Cheers... jondee86
03-30-2011, 11:29 AM
Jan Pedersen Wrote:~9 mm but fittings are smaler. The mocal plate can only be mounted one way.
Yeah, 9mm is really cutting it close if the fittings are a bit thick & crude & more if you've got any 90's in there.
It's not the mocal, it's which line goes where!
Come up with anything on that RX7's inlet & outlet? I imagine that they can't be reversed without consequences on anything with a built in thermostat.
04-02-2011, 09:05 PM
The pressure is ok with the bigger hoses Smile
06-08-2011, 10:48 AM
Mocal make 2 different oil cooler adapters / sandwich plates.
One style is thermostatic, and the other style is normal.
With the thermostatic one the oil pressure will vary at the oil cooler but would stay steady in the engine (one would hope).
With the normal one you should have full pressure everywhere all the time including in the oil cooler.
06-04-2013, 01:42 AM
Digging up an old thread Smile
Basicly got a stockish 20V BT on Emerald ECU, stacks and exhaust. I was about to fit a oilcooler, for piece of mind, but remembered hearing about oil pressure VVTi issues in the past...
My plan was to remove everything from the block and run a mocal thermostatic sandwich plate without any oil filter relocation, using dash 8 hose and a cooler that has the same size as the old one out of the 16V engine.
Planned on using Castrol 10W60.
After reading this thread, I'm cosindering dash10 instead???
Googled it and came across different opinions, so I'm looking for other peoples opinions on this...
Help please Banging head
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
  Mocal oil cooler & sandwitch plate ordered Gtsi-R 48 55,011 11-18-2022 02:19 PM
Last Post: FanIsHere
  Oil cooler totta Crolla 0 1,553 07-25-2021 03:25 PM
Last Post: totta Crolla
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 20,953 08-19-2018 12:08 PM
Last Post: AlexKTM
  Silver top low idle AlexFourTwenty 7 10,138 10-16-2017 10:22 PM
Last Post: AlexFourTwenty
  Oil cooler kit izanagi 7 8,609 09-20-2016 11:13 AM
Last Post: harkes
User(s) browsing this thread: 12 Guest(s)
