Oil from head to air collector in 4age when drifting left.
04-24-2008, 11:25 PM
Need your help! I've got very high compression ratio in my 4age (about 16 bars), and when I'm drifting left oil from head goes to air collector and leaks from air filter. The cable that you see in red circle on the picture was straight and it was TERRIBLE. Now it's a bit better, but still not good. Anyone had problem like this, how did you solved this?
Thanks a lot!!!! |
04-24-2008, 11:58 PM
Been covered many times... search and you will find Basically you
need to take that hose into a "catch can" to separate the oil, then take a vent hose back to the inlet manifold. Use a sealed can with a level tube on the outside, and empty the can when you have half a litre of oil inside You can buy a catch can from a car accessories store, or make one yourself if you have some tools. You can easily see how they are made by making a search on the web. Cheers... jondee86 |
04-25-2008, 12:19 AM
Thanks a lot!! I thought that it was only in my engine
thabks! |
04-25-2008, 08:24 AM
this is new to me. I always wonder why my intake manifold was really diry in the first place.
anyone got a pic of a good fiting for this. Im going to research this. East Coast Toyota http://ectoyotas.com/forum/index.ph Club4AG http://www.club4ag.com/ |
04-25-2008, 01:47 PM
Discharging oil into the intake requires two things... sustained high
rpm to pump a lot of oil up into the cam covers, and a long, high speed left turn. This "centrifuges" the excess oil over to the right of the head where the crankcase vent is located. It is then blown out the vent tube, and finds its way into the air intake. Usually only a problem with the TVIS bigport motors, as smallport and later motors had better oil drains from the head. The tube that you see entering the side of the plenum is channeled internally up a duct that vents into the intake just in front of the throttle butterfly. Some will get sucked into the engine to make smoke Some will drain down to the filter. Google "Cusco" or "Greddy" and "catch can" to see two examples of a universal sealed can. There are other cheaper ones around, available from auto parts supermarkets. Cheers... jondee86 |
04-25-2008, 03:16 PM
just swap the cam covers around ......
04-25-2008, 09:43 PM
What gon said is the best idea... just swap camp covers left to right and run a catch can if you want.
Fitting Air Con (No PS) to LHD AE86 | pack | 7 | 4,156 |
01-07-2024 11:36 AM Last Post: CCB |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,095 |
Inside of front wheel touches frame rails during drifting | bozu | 3 | 1,805 |
06-09-2022 04:51 PM Last Post: Project D |
Air Cleaner Assembly | Hama86 | 7 | 9,341 |
10-29-2018 03:28 AM Last Post: Hama86 |
AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 17,417 |
08-16-2018 01:36 AM Last Post: Bean |
