Oil leaking from top but its not broken ???
04-29-2008, 09:07 PM
i have started the engine now and took it for a spin.. i have noticed that oil are leaking somewhere... between the top and the cylinder block.. can not see exactly but someone maybe knows of this.. Thanks!
DonĀ“t Think About The Past, Live In The Present And Dream About Tomorrow |
04-29-2008, 09:52 PM
Distributor oil seal
Valve cover gasket Camshaft seals (not likely) Those are the obvious things to look out for. FABRICA MI DIEM, PVNC! |
05-09-2008, 07:46 PM
Make sure you're valve cover grommets and valve cover seals are still good. When using new valve cover seals you have to use the Toyota FIPG on 2 spots for each valve cover seal.
05-09-2008, 07:48 PM
camshafts seals.i have the same problem.
Red top in the ae86 | gh0st | 25 | 10,843 |
08-08-2022 08:43 PM Last Post: gh0st |
Replacing Top Windscreen Moulding | chrisae86 | 2 | 2,057 |
Engine starts/revs but no idle | GenkiMotors | 17 | 7,466 |
Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 7,527 |
Silver top low idle | AlexFourTwenty | 7 | 10,232 |
10-16-2017 10:22 PM Last Post: AlexFourTwenty |
