Oil leaking from top but its not broken ???
04-29-2008, 09:07 PM
i have started the engine now and took it for a spin.. i have noticed that oil are leaking somewhere... between the top and the cylinder block.. can not see exactly but someone maybe knows of this.. Thanks!
DonĀ“t Think About The Past,
Live In The Present And
Dream About Tomorrow
04-29-2008, 09:52 PM
Distributor oil seal
Valve cover gasket
Camshaft seals (not likely)
Those are the obvious things to look out for.
05-09-2008, 07:46 PM
Make sure you're valve cover grommets and valve cover seals are still good. When using new valve cover seals you have to use the Toyota FIPG on 2 spots for each valve cover seal.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
1989 Honda Civic Si-R Current Project
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
05-09-2008, 07:48 PM
camshafts seals.i have the same problem.
  Red top in the ae86 gh0st 25 10,285 08-08-2022 08:43 PM
Last Post: gh0st
  Replacing Top Windscreen Moulding chrisae86 2 1,972 06-18-2022 08:56 PM
Last Post: chrisae86
  Engine starts/revs but no idle GenkiMotors 17 7,128 11-20-2021 04:12 AM
Last Post: GenkiMotors
  Early tvis red top from e9 gti small or bigport? Ryo 3 7,445 04-20-2018 09:14 AM
  Silver top low idle AlexFourTwenty 7 10,124 10-16-2017 10:22 PM
Last Post: AlexFourTwenty
