What bar is it?
08-07-2018, 12:27 AM (This post was last modified: 08-07-2018 12:28 AM by FanIsHere.)
What bar is it?
Hello everyone.
Recently I bought some used chassis bars for my AE86 (front and rear strut bars and a tension rod bar) through e-bay and the seller send me also this bar, which I don't know what for it is. He said that it's for the rear underneath, so I think that he meant the rear axle -> panhard bar, but it doesn't seem like one, because it has two same ends.
Does anyone know what this bar is?
[Image: AEU86 AE86 - What bar is it?]
Follow: The story of my AE86
08-07-2018, 01:46 AM
What bar is it?
Think this is meanth to go between the C-pillars on the hatch. They usually mount to the bolts holding the seatbelt.
Something like this
https://technotoytuning.com/toyota/ae86/...86-corolla
Assuming you don't have any spare mounting plates to go with it.
Sent from my MHA-L29 using Tapatalk
AE86 ex-daily
08-07-2018, 07:59 AM
What bar is it?
If one rod end is bigger than the other, then it is probably one of these...
http://grp4fabrications.com/product_info...cts_id=812
Cheers... jondee86
08-07-2018, 09:38 PM
What bar is it?
(08-07-2018 01:46 AM)Bean Wrote:  Think this is meanth to go between the C-pillars on the hatch. They usually mount to the bolts holding the seatbelt.
Something like this
I don't have anything else.
(08-07-2018 07:59 AM)jondee86 Wrote:  If one rod end is bigger than the other, then it is probably one of these...
Cheers... jondee86
Unfortunately both rod ends are the same.
08-08-2018, 12:06 AM
What bar is it?
They could be the same size. It's been a while since I was under
the car Smile And there is nothing else that bar could be used for that
I can think of.
Cheers... jondee86
08-08-2018, 02:44 AM (This post was last modified: 08-08-2018 02:44 AM by Bean.)
What bar is it?
Can you post a close up picture of the two ends? (maybe at a slight angle)
AE86 ex-daily
08-08-2018, 11:33 AM
What bar is it?
What length is the bar, bearing centre to centre ?
Measure your Panhard rod to see if it is the same.
10-20-2018, 12:14 PM
What bar is it?
Hello again and sorry for disappearing, but I totally forgot about it. So..
(08-08-2018 02:44 AM)Bean Wrote:  Can you post a close up picture of the two ends? (maybe at a slight angle)
Here you go: https://imgur.com/8TR4bah & https://imgur.com/yj4T8bB
(08-08-2018 11:33 AM)totta Crolla Wrote:  What length is the bar, bearing centre to centre ?
The bar is 104cm from center to center as it is now. I have to measure my panhard rod, but I have to lift the car firstly. Do you know maybe what's the lenght of a stock AE86 panhard rod?
  Bash bar for zenki trueno bumper gh0st 3 1,348 02-08-2023 10:50 PM
  Front Anti Roll Bar for Beams Swap KD2229 5 6,169 09-20-2011 10:04 AM
Last Post: Aram
  OEM sway bar thickness ?? T_AE86 5 11,606 08-07-2011 04:05 PM
Last Post: Hachi
  Adjustable Panhard Rod Bar christsang7 7 10,852 07-12-2010 04:42 PM
Last Post: eight-six
  Sway Bar ?? juantonwan 17 16,131 05-10-2010 05:04 PM
Last Post: juantonwan
