Oil plug thread size is M18x1.5 ????
06-07-2012, 11:36 AM
I guess title is clear.
Thanks already Thumbs up! Thumbs up!
06-07-2012, 04:02 PM
Toyota = M12 X P1.25 for the oil pan drain bolt.
06-07-2012, 04:36 PM
Really??
It looks way bigger.
Spanner size is Hex 19.
Maybe later Engines used hex 14 which might be M12
Mine is an '84 model
06-07-2012, 04:45 PM
You're talking about the engine oil drain plug, right ?
I never seen any Toyota with anything other than m12x1.25.
From a KE70 to a supra mk4, they all have the same plug...
So, if your plug is different, then it have been modified...
06-07-2012, 04:54 PM
Indeed it's the engine oil plug.
It should be standard still on my car. So it's M12 ...
Anyway, I will consider making an early oil change to check the size to be sure... :wink:
Thanks Thumbs up!
  Ignition switch plug and wires Blaze0010 3 1,182 11-25-2024 12:29 PM
Last Post: Blaze0010
  4AGE cylinder head plug removal Ivan141 5 3,055 09-30-2023 09:47 PM
  Plug ID kazi 6 7,243 02-17-2019 10:07 PM
Last Post: kazi
  Shim size for AM cams kazi 4 5,885 12-18-2017 05:34 PM
Last Post: oldeskewltoy
Wink Hub size kazi 5 10,611 06-09-2017 10:06 PM
Last Post: kazi
