Omex ITB's setup
01-28-2008, 02:08 AM
Omex ITB's setup
Hello all, has any one had experience with the omex ITB setup for the 4age?
http://www.omextechnology.co.uk/Throttle...AGE16v.htm
Looks pretty kewl, although maybe some what expensive...
01-28-2008, 06:16 PM
Omex ITB's setup
how much it cost? Blush
SR Team
BURN THE RUBER NOT YOUR SOUL!
01-28-2008, 10:33 PM
Omex ITB's setup
£1700~ish for every thing on that link.
02-12-2008, 01:38 AM
Omex ITB's setup
You could make yourself a similar setup for alot less. I used the following.
T3 Inlet Manifold - 125GBP
20v ITB's - 150GBP
Perfect Power Stand alone ECU - 490GBP
Air filter - 60GBP
Trigger wheel/sensor/coilpack etc. - 50GBP
Pretty simple really
works and runs well.
Link below
http://www.youtube.com/watch?v=jTvG3lh5og4&feature=user
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
02-12-2008, 10:42 AM
Omex ITB's setup
Kewl, cheers for that. it works out quite a bit cheaper.
What sort of power increase do you get with that setup?
02-15-2008, 12:56 PM
Omex ITB's setup
Didn't really get the power I was expecting, but I was running a very poor exhaust manifold at the time. I now fitted a modified FWD OBX header and there seemed to be more power at the top end. My little engine is very tired aswell, burns quite alot of oil. Probably got about 15bhp, but honestly feels like more. It sound like it has 200bhp :wink:
You would probably need head/cams etc to extract the best out of them. But at least if the engine blows up, there has been no money spent on it internally, and another standard engine will give you the same power.
Ivan
  4 Link setup and Traction brackets Jezza_hr 5 10,293 07-21-2014 09:12 PM
  DIV 1 rally/track suspension setup ditn 60 72,188 03-28-2013 11:28 PM
Last Post: ditn
  Fuel system setup 86Pilot 2 4,778 01-30-2013 04:24 PM
  MSD 8980 setup - which wire does the dizzy connect to? megabob 8 17,036 11-22-2011 07:02 PM
Last Post: Project D
  Setup steer-in versus traction Dino86 6 7,866 11-15-2011 11:46 AM
Last Post: Dino86
