Original gauge with universal fuel sender
01-04-2015, 08:42 PM
Hello.
I have to replace the old rusted fueltank with universal aluminum fuelcell.
Has anyone tried does the original AE86 gauge work with universal fuel level sender or do I have to make place for the original fuel level sender to the aluminum fuelcell ?
Thanks in advance for all the help.
Drive fast, or crash when trying...
01-04-2015, 10:16 PM
What mater is the "signal"
If you can find an universal fuel level sender that give you ~3 ohms when full and ~100 ohms when empty, you're good.
01-05-2015, 09:38 AM
This was just the info I was looking for, just had a little "brainfreeze" and couldn't write it right..Tongue
This happens sometimes when you're not native English speakerBlush
The sender is from 0 to 90 ohms, so, i'll take my chance with it.
Thanks alot !
01-05-2015, 10:40 AM (This post was last modified: 01-05-2015 10:40 AM by Project D.)
If your sender work between 0 and 90, add a 5 ohms in serie (not in parallel) that should make you very close to the OEM.
(and English is not my native language neither Tongue )
01-05-2015, 03:27 PM
I'll do that, tank for the great advice.Respect!
  EUDM gauge cluster banpei 22 4,919 08-15-2023 10:48 PM
  Can you convert your 86 back too the original state? gh0st 7 3,038 04-25-2022 04:25 PM
Last Post: gh0st
  Restoring original pizzacutter center caps banpei 17 9,176 06-24-2021 10:58 PM
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 7,699 12-06-2017 06:48 PM
  Analog gauge cluster tech Ivan141 33 42,537 01-31-2016 11:06 PM
