Original gauge with universal fuel sender
01-04-2015, 08:42 PM
Hello.
I have to replace the old rusted fueltank with universal aluminum fuelcell. Has anyone tried does the original AE86 gauge work with universal fuel level sender or do I have to make place for the original fuel level sender to the aluminum fuelcell ? Thanks in advance for all the help. Drive fast, or crash when trying... |
01-04-2015, 10:16 PM
What mater is the "signal"
If you can find an universal fuel level sender that give you ~3 ohms when full and ~100 ohms when empty, you're good. |
01-05-2015, 09:38 AM
This was just the info I was looking for, just had a little "brainfreeze" and couldn't write it right..
This happens sometimes when you're not native English speaker The sender is from 0 to 90 ohms, so, i'll take my chance with it. Thanks alot ! Drive fast, or crash when trying... |
01-05-2015, 10:40 AM
(This post was last modified: 01-05-2015 10:40 AM by Project D.)
If your sender work between 0 and 90, add a 5 ohms in serie (not in parallel) that should make you very close to the OEM.
(and English is not my native language neither )
01-05-2015, 03:27 PM
I'll do that, tank for the great advice.
| How to: Repair low fuel warning sender | Sanity Clause | 3 | 40,204 |
05-19-2025 11:05 PM Last Post: Sanity Clause |
| EUDM gauge cluster | banpei | 22 | 9,498 |
| Can you convert your 86 back too the original state? | gh0st | 7 | 4,989 |
04-25-2022 04:25 PM Last Post: gh0st |
| Restoring original pizzacutter center caps | banpei | 17 | 12,721 |
06-24-2021 10:58 PM Last Post: banpei |
| Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 9,940 |
