PLEASE - SUPERFAST HELP REQUIRED - PICTURES
05-30-2005, 11:18 PM
What does this "THING" do for the clutch-oil.
It it fitted 20cm before the clutchcylinder that pushes on the clutch itself. this item also has it´s own bleeding screw & it has anshort rubber line into & out of it which supports the clutch-oil - if I remove this thing i´d be able to fit an single clutch-line all the way from the clutchmaster-cylinder = MUCH better than stock. WOULD THIS BE POSSIBLE ? I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
05-30-2005, 11:54 PM
kris i wouldn't do it...... its there not for nothing.... i've never seen this MOD on a AE86. If you go time to exchange it twice you can test it but i wouldn't recommend it without consulting race build AE86's
05-31-2005, 08:37 AM
Don't have that thing on my car.....
05-31-2005, 08:41 AM
I think it's just what you can see from the outside...a bleed valve. Especially if it's mounted in the top of a loop. But dont go guessing, try looking it up in EPC, I cant help you out since I'm at work..
05-31-2005, 10:34 AM
thanxs - I have just learned what this is..
It´s a extra bleed valve / restrictor för the clutch-oil. the restrictor allows for a smoother clutchslip. just remove it i have been told kris I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
TUV RHD AE86 Germany (help please) | 4dori | 9 | 7,472 |
07-17-2019 07:42 PM Last Post: Hachigo83 |
Detailed LHD engine bay pictures | Bean | 0 | 3,122 |
08-05-2018 04:09 PM Last Post: Bean |
Carb question please help | MIGGZFSU | 3 | 4,942 |
03-29-2017 03:06 PM Last Post: MIGGZFSU |
Whining noise HELP PLEASE | izanagi | 10 | 12,837 |
03-26-2015 06:48 PM Last Post: Komba |
the connector saga (please help everyone) | Bean | 8 | 9,624 |
06-23-2014 01:13 PM Last Post: Bean |
