PWR light issue and no brake fluid after winter storage
05-15-2023, 06:32 PM
RE: PWR light issue and no brake fluid after winter storage
(05-15-2023 08:43 AM)Ivan141 Wrote:  Econ / Pwr light functions on vacuum. Check your vacuum lines to see if a rodent might have taken a nibble from one during winter.
The switch is on the right fender near the inlet manifold IIRC.
I would not take any chances with your brake system. It must be leaking somewhere since last time I checked the pixies dont come to suck it out over winter.
Since I dont know your car yet, perhaps you could tell us what model you have exactly. If you have an SR5 with drum brakes you might have a leaky rear cylinder.
On disk brakes everything should be in plain sight. Perhaps sprinkle some talkum powder around the brakes and leave it to sit for a few days. Any leaks will leave traces in the powder.
I checked the lines going to the vacuum sensor valve, the one with two nipples coming out of it if that is the one you're talking about. From what I can tell they seem to have been disconnected previously. I tried connecting them but the pwr light is still there, however the idle speed dropped a little. I couldn't see anything wrong with the rest of the vacuum lines, but I will take a closer look.
The car is a EU spec 3 door, I guess that would be closer to the GTS as far as US spec goes. In other words I got disc brakes. If brake fluid were to leak onto the floor, wouldn't the stains stay there for a long time? Any chance the fluid could leak into the brake booster?
Messages In This Thread
RE: PWR light issue and no brake fluid after winter storage - magpie - 05-15-2023 06:32 PM
  ECON and PWR light troubleshooting magpie 3 1,624 07-18-2023 01:28 PM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,349 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  Fuel pump issue DJexor 11 4,975 04-29-2022 05:45 AM
  Clutch Issue Deaty 8 4,214 04-09-2021 10:26 PM
Last Post: Nakilad
  5th gear issue r.ave 1 2,538 03-14-2021 08:52 PM
