Paradise Racing clutch (6puk) with stock pressure plate
05-02-2007, 05:15 PM
Has anyone ever ride with this setup? I'm installing a Paradise Racing clutch (6 puk, sprung) in a stock (almost new with 10k miles on it) clutch cover - pressure plate.
I also have a TODA light flywheel.
I'm using it for street and track. Let me know your thoughts...
Thank you
05-02-2007, 06:35 PM
not enough face pressure...
Ideally you want to increase the clamping load on the disc BEFORE you go to racing, or semi racing discs. Doing it your way will only boost holding power minimally... if at all. Get a HD pressure plate and you'll be doing better...
Dan -
05-03-2007, 12:35 AM
But have you tried it?
I would like to have references from people who had experienced it.
(not that your statement isn't valid, it seems more than correct)
Best regards
  Mocal oil cooler & sandwitch plate ordered Gtsi-R 48 55,956 11-18-2022 02:19 PM
Last Post: FanIsHere
  Digital speedometer on stock dashboard FanIsHere 0 1,477 11-09-2022 01:36 PM
  82mm Stock compression Pistons apardal 4 2,912 11-24-2021 04:26 PM
Last Post: apardal
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,685 07-18-2019 03:52 PM
  Most stock-resembling exhaust for the AE86? DaLanZhu 4 5,732 03-24-2019 04:10 PM
