Paradise Racing clutch (6puk) with stock pressure plate
05-02-2007, 05:15 PM
Has anyone ever ride with this setup? I'm installing a Paradise Racing clutch (6 puk, sprung) in a stock (almost new with 10k miles on it) clutch cover - pressure plate.
I also have a TODA light flywheel. I'm using it for street and track. Let me know your thoughts... Thank you |
05-02-2007, 06:35 PM
not enough face pressure...
Ideally you want to increase the clamping load on the disc BEFORE you go to racing, or semi racing discs. Doing it your way will only boost holding power minimally... if at all. Get a HD pressure plate and you'll be doing better... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-03-2007, 12:35 AM
But have you tried it?
I would like to have references from people who had experienced it. (not that your statement isn't valid, it seems more than correct) Best regards |
Mocal oil cooler & sandwitch plate ordered | Gtsi-R | 48 | 55,956 |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,477 |
82mm Stock compression Pistons | apardal | 4 | 2,912 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 13,685 |
Most stock-resembling exhaust for the AE86? | DaLanZhu | 4 | 5,732 |
03-24-2019 04:10 PM Last Post: oldeskewltoy |
