Performance Spark Plugs
01-03-2008, 02:05 AM
What are the best plugs to buy for the 4age, Ive had the standard & TRD irridium & neither are able to handle the fueling in the race car, cutting the fuel isnt an option unless I can find someone still capable of programming a 1983 TRD e-prom ecu
01-03-2008, 02:21 AM
if the afr values are too rich no spark plug will help you ...
and you will eventually damage your engine if the afr is below about 10
try a fuel pressure regulator and reduce the pressure
but you should buy a wideband lambda sensor or you might damage your engine
01-03-2008, 03:07 AM
Im sure the fuel pressure is ok, its just the amount!!!, once the car is warmed up its ok, I tried to start it the other day & it took me 2 hours, warming up plugs works.
the cams are 11mm lift 320 deg,
01-03-2008, 04:20 AM
Eircamae86 Wrote:Im sure the fuel pressure is ok, its just the amount!!!, once the car is warmed up its ok, I tried to start it the other day & it took me 2 hours, warming up plugs works.
some race engines use 2 set of sparksplugs
1 set is the warmup plugs
and the other set is the race plugs
I guess the warmupplugs might be 1 or 2 degree hotter than the race plugs
3x ke70, 2x te71, 2x ae86, 1x ke20 and 1x hilux
01-03-2008, 06:42 PM
if you reduce the fuel pressure the fuel amount injected will also reduce....
that's what I was referring to.
01-03-2008, 09:50 PM
I must buy 2 good quality sets, as you said 1 for warm up only, I leave the plugs sitting on the manifold of a hot car for about 10minutes, this usually works, but if it doesnt start 1st turn, the plugs fowl & the plugs must be removed/cleaned & warmed up again. Pain in the A$$
01-06-2008, 08:31 PM
I would try connecting up an AFR, and fuel pressure guage and see what it is reading, could upgrade to a more modern management system such as Motec if its really a problem.
Superb car btw!
  Weak spark, doesn’t start. AlexFourTwenty 4 16,064 12-12-2017 03:35 AM
Last Post: AlexFourTwenty
  weir performance email filh 2 4,977 06-14-2015 05:37 PM
  Weir Performance rear upgrade kit for AE86 heshan 5 9,444 07-22-2013 09:11 PM
Last Post: heshan
  Core Plugs Alex170984 6 8,339 06-10-2013 07:59 PM
Last Post: The Doctor
  20v no spark & dry plugs. Rascal21 26 36,548 05-10-2013 02:47 AM
Last Post: Rascal21
