Performance Spark Plugs
01-03-2008, 02:05 AM
What are the best plugs to buy for the 4age, Ive had the standard & TRD irridium & neither are able to handle the fueling in the race car, cutting the fuel isnt an option unless I can find someone still capable of programming a 1983 TRD e-prom ecu
01-03-2008, 02:21 AM
if the afr values are too rich no spark plug will help you ...
and you will eventually damage your engine if the afr is below about 10 try a fuel pressure regulator and reduce the pressure but you should buy a wideband lambda sensor or you might damage your engine |
01-03-2008, 03:07 AM
Im sure the fuel pressure is ok, its just the amount!!!, once the car is warmed up its ok, I tried to start it the other day & it took me 2 hours, warming up plugs works.
the cams are 11mm lift 320 deg, An 86 is for Life, not just for Christmas |
01-03-2008, 04:20 AM
Eircamae86 Wrote:Im sure the fuel pressure is ok, its just the amount!!!, once the car is warmed up its ok, I tried to start it the other day & it took me 2 hours, warming up plugs works. some race engines use 2 set of sparksplugs 1 set is the warmup plugs and the other set is the race plugs I guess the warmupplugs might be 1 or 2 degree hotter than the race plugs 3x ke70, 2x te71, 2x ae86, 1x ke20 and 1x hilux |
01-03-2008, 06:42 PM
if you reduce the fuel pressure the fuel amount injected will also reduce....
that's what I was referring to. |
01-03-2008, 09:50 PM
david Wrote:Eircamae86 Wrote:Im sure the fuel pressure is ok, its just the amount!!!, once the car is warmed up its ok, I tried to start it the other day & it took me 2 hours, warming up plugs works. I must buy 2 good quality sets, as you said 1 for warm up only, I leave the plugs sitting on the manifold of a hot car for about 10minutes, this usually works, but if it doesnt start 1st turn, the plugs fowl & the plugs must be removed/cleaned & warmed up again. Pain in the A$$ An 86 is for Life, not just for Christmas |
01-06-2008, 08:31 PM
I would try connecting up an AFR, and fuel pressure guage and see what it is reading, could upgrade to a more modern management system such as Motec if its really a problem.
Superb car btw! |
Weak spark, doesn’t start. | AlexFourTwenty | 4 | 15,391 |
weir performance email | filh | 2 | 4,793 |
06-14-2015 05:37 PM Last Post: oldeskewltoy |
Weir Performance rear upgrade kit for AE86 | heshan | 5 | 9,143 |
07-22-2013 09:11 PM Last Post: heshan |
Core Plugs | Alex170984 | 6 | 8,104 |
06-10-2013 07:59 PM Last Post: The Doctor |
20v no spark & dry plugs. | Rascal21 | 26 | 35,473 |
05-10-2013 02:47 AM Last Post: Rascal21 |
