Performance parts
11-22-2018, 11:02 PM
Performance parts
Hi,
wondering where folks are buying aftermarket pistons and rods from? I'm getting not very much selection when I'm looking so wondering where people go. TIA |
11-28-2018, 07:03 PM
Performance parts | |||
11-29-2018, 09:22 PM
(This post was last modified: 11-29-2018 09:25 PM by oldeskewltoy.)
Performance parts
depends....
I happen to like Molnar rods, you can get them directly - http://www.molnartechnologies.com/rods-sc-toyota.html But typically rods are for substantial builds, mild to moderate builds can easily use the OEM rods pistons are another story...MANY places have them... few are actually a useful piston... ![]() camshafts are also available from many different sources, I happen to like the offerings from Cat cams - shorter ramps, and a bit more lift them many of the other offerings. Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
11-30-2018, 01:55 PM
Performance parts
If you're building a Revy 16v, OEM Blacktop rods still the choice?
11-30-2018, 06:44 PM
Performance parts
(11-30-2018 01:55 PM)mad.matt Wrote: If you're building a Revy 16v, OEM Blacktop rods still the choice? depends... on a 42mm rod journal crankshaft... and keeping the rods OEM - then yes Bu that is a lot of conditions. Molnar rods are stronger, and a bit lighter, and @ under $500 pretty damn cheap. Molnar is also the only rod company that has a rod for the smaller 40mm rod journal crank... AND the small end is 20mm to fit whatever piston you'd like...... Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-04-2018, 12:07 AM
Performance parts
ah, forgot I asked this question. MPR, battelgarage and RHD I have looked at and all that I really got. I'll have a look at real street etc.
I'm wanting to put the 16v to work so while the engine is apart I might as well go for a forge option. Gives me more scope to run mild power or kick the arse out of it. currently 42mm crank I have but still need to get them inspected to see if they are fine. |
12-11-2018, 06:55 PM
Performance parts
What about Toda adjustable cam gears? Does anyone knows if they are available somewhere in Europe maybe?
![]() Follow: The story of my AE86 |
12-11-2018, 07:42 PM
Performance parts
There are a few importers but very few carry stuff like this in stock so you might as well get it yourself.
I personally used perfectrun.jp a lot. You can also send them an email for stuff not listed in the shop, if it's from Japan they most likely can get it. Sent from my MHA-L29 using Tapatalk AE86 ex-daily |
12-12-2018, 08:44 AM
(This post was last modified: 12-12-2018 08:46 AM by d3nso.)
Performance parts
If you need stuff specific from Japan you can shoot Robert from EPImporters/EtsuRyu a mail with what you need:
https://www.etsuryu.com I used his service serval times in the past and can fully recommend his business ![]() Daily Beater: Civic EG5 Work in progress Car: AE86 |
12-12-2018, 03:12 PM
Performance parts
Are they (EtsuRyu and perfectrun) better than RHDJapan? I'm afraid of import taxes that's why I was looking something from European wharehouse.
Weir performance | pack | 3 | 5,717 |
10-20-2016 10:48 AM Last Post: Bean |
Weir Performance | filh | 1 | 5,056 |
06-05-2015 10:33 AM Last Post: Bean |
[Info] - Team Caetano Racing website - Performance parts | Rasteirinho | 4 | 6,530 |
11-18-2011 11:06 PM Last Post: Rasteirinho |
