Pillow Ball Tension Rods for AE86
09-27-2010, 10:13 AM
These Pillow Ball Tension Rods (Castor Rods) are the best available on the of it's type for the AE86. These Tension Rods (Castor Rods) allows you to adjust the castor on the front suspension. It also comes with the reinforced brackets to replace the old weak stock ones. This improves ridgity and helps the body reduce flexing which will benefit with improved steering response and cornering. Reduces the amount of suspension flex during hard cornering.
Greatly increases the handling response going into corners by adopting pillow ball mount on the body side. High rigidity pillow rods balls used to hold down tires under braking. Increases straight line stability by reducing toe out. APPLICATION: - Toyota Corolla Levin, Sprinter Trueno AE86 1984-1987 NOTES: - You will need to have a complete wheel allignment and geometry settings done by professionals after installation. ready to ship ! price $350 +shipping. ![]() |
09-27-2010, 10:42 AM
Give us an estimate on shipping to Europe please.
![]() danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
AE86 Relocated Tension Rod Brackets | ep71 | 1 | 5,733 |
07-10-2012 09:47 AM Last Post: ep71 |
MCN:Coming soon D-Mac AE86 Lower Control Arm/Tension Rod Kit | MCNSPORT.com | 6 | 9,391 |
07-05-2012 02:13 AM Last Post: MCNSPORT.com |
AE86 Adjustable Tension Rod Kit | ep71 | 1 | 5,477 |
03-12-2012 11:20 PM Last Post: ep71 |
NEWERA - CUSTOM PILLOW BALL REAR LINKS. | Miguel - Newera | 6 | 7,808 |
08-28-2008 12:17 AM Last Post: V-t-e-c |
