Pillow Ball Tension Rods for AE86
09-27-2010, 10:13 AM
These Pillow Ball Tension Rods (Castor Rods) are the best available on the of it's type for the AE86. These Tension Rods (Castor Rods) allows you to adjust the castor on the front suspension. It also comes with the reinforced brackets to replace the old weak stock ones. This improves ridgity and helps the body reduce flexing which will benefit with improved steering response and cornering. Reduces the amount of suspension flex during hard cornering.
Greatly increases the handling response going into corners by adopting pillow ball mount on the body side. High rigidity pillow rods balls used to hold down tires under braking. Increases straight line stability by reducing toe out.
APPLICATION:
- Toyota Corolla Levin, Sprinter Trueno AE86 1984-1987
NOTES:
- You will need to have a complete wheel allignment and geometry settings done by professionals after installation.
ready to ship !
price $350 +shipping.
[Image: AEU86 AE86 - Pillow Ball Tension Rods for AE86]
09-27-2010, 10:42 AM
Give us an estimate on shipping to Europe please. Thumbs up!
[Image: AEU86 AE86 - Pillow Ball Tension Rods for AE86] http://www.jdmbits.com
  AE86 Relocated Tension Rod Brackets ep71 1 5,434 07-10-2012 09:47 AM
Last Post: ep71
  MCN:Coming soon D-Mac AE86 Lower Control Arm/Tension Rod Kit MCNSPORT.com 6 8,643 07-05-2012 02:13 AM
Last Post: MCNSPORT.com
  AE86 Adjustable Tension Rod Kit ep71 1 5,188 03-12-2012 11:20 PM
Last Post: ep71
  NEWERA - CUSTOM PILLOW BALL REAR LINKS. Miguel - Newera 6 7,194 08-28-2008 12:17 AM
Last Post: V-t-e-c
