Please help !!
09-13-2005, 09:28 PM
Please help !!
This is a little urgent as we are entered for a rally Saturday.
O.k, changed gearbox because I could not select 4th from 5th now guess what ? Replacement 'box won't go from 4th to 3rd, I am assured that this 'box is good. When it was out I noticed that the clutch slave cylinder was leaking fluid, does anyone know if this could be to blame although all other gears work fine. Thanks for any help An analogue brain in a digital World |
09-14-2005, 09:28 AM
Please help !!
Could very well be the problem. The clutch doesn't fully disengage and that leaves some stress on the driveline.
09-14-2005, 10:47 PM
Please help !!
Great
![]() An analogue brain in a digital World |
09-14-2005, 11:38 PM
Please help !!
if the box will go into all the other gears apart from 4th to 3rd its the box not the clutch cylinder
AE86 gearboxes are made out of plastacine, you should know that cos all the arrive alive cars had Ford boxes fitted Good luck, which raaly are you out on? ![]() |
TUV RHD AE86 Germany (help please) | 4dori | 9 | 7,413 |
07-17-2019 07:42 PM Last Post: Hachigo83 |
Carb question please help | MIGGZFSU | 3 | 4,895 |
03-29-2017 03:06 PM Last Post: MIGGZFSU |
Whining noise HELP PLEASE | izanagi | 10 | 12,765 |
03-26-2015 06:48 PM Last Post: Komba |
the connector saga (please help everyone) | Bean | 8 | 9,580 |
06-23-2014 01:13 PM Last Post: Bean |
AE 101 - 111 ITB Question, please help | ZDoman | 12 | 15,191 |
02-03-2013 09:39 PM Last Post: banpei |
