Please help !!
09-13-2005, 09:28 PM
Please help !!
This is a little urgent as we are entered for a rally Saturday.
O.k, changed gearbox because I could not select 4th from 5th now guess what ? Replacement 'box won't go from 4th to 3rd, I am assured that this 'box is good.
When it was out I noticed that the clutch slave cylinder was leaking fluid, does anyone know if this could be to blame although all other gears work fine.
Thanks for any help
09-14-2005, 09:28 AM
Please help !!
Could very well be the problem. The clutch doesn't fully disengage and that leaves some stress on the driveline.
09-14-2005, 10:47 PM
Please help !!
Great Smile thanks for that allways worth a try.... all I need now is to get another one !!
09-14-2005, 11:38 PM
Please help !!
if the box will go into all the other gears apart from 4th to 3rd its the box not the clutch cylinder
AE86 gearboxes are made out of plastacine, you should know that cos all the arrive alive cars had Ford boxes fitted
Good luck, which raaly are you out on?
[Image: AEU86 AE86 - Please help !!]
  TUV RHD AE86 Germany (help please) 4dori 9 6,770 07-17-2019 07:42 PM
Last Post: Hachigo83
  Carb question please help MIGGZFSU 3 4,611 03-29-2017 03:06 PM
Last Post: MIGGZFSU
  Whining noise HELP PLEASE izanagi 10 12,011 03-26-2015 06:48 PM
Last Post: Komba
  the connector saga (please help everyone) Bean 8 9,102 06-23-2014 01:13 PM
  AE 101 - 111 ITB Question, please help ZDoman 12 14,364 02-03-2013 09:39 PM
